"If the MLPS needs replacement, use Ford part# E5TZ-7A247-A. This kit includes the new style harness connector. You must replace the connector to use the new MLPS. By sliding the old wire separator from the original connector up the harness you can leave it in place as you install the new connector. This helps keep wires in their original location." R.A.
