Fuel pressure port
Old May 23, 2017 | 11:00 AM
Rod Jr.'s Avatar
Rod Jr.
Fuel pressure port
Is there a reason why the test port adapter cannot be left installed permanently? They all say temporary use only.
Old May 23, 2017 | 11:38 AM
bismic's Avatar
bismic
I think they are just covering their rear.
Mine is permanent, along w/ the hose and the sensor.
Old May 23, 2017 | 11:46 AM
Rod Jr.'s Avatar
Rod Jr.
That makes sense, my main concern was that o-ring. Why did they not just use a copper washer?
Old May 23, 2017 | 11:50 AM
bismic's Avatar
bismic
I ordered Viton O-rings for mine. they are a little more durable.
I suppose O-rings are more appropriate for a component that may get installed and removed multiple times.
Old May 23, 2017 | 12:08 PM
packagerjr's Avatar
packagerjr
O-rings are a zero seating stress, pressure-energized seal. You don't have to tighten the bejeezus out of an o-ring fitting to make it work - once you go metal-to-metal, you are there. In an application like our filter housing (which I'm almost sure is aluminum), trying to seat a copper washer could result in a run on replacement housings and a boatload of unhappy 6.0 owners.
Back on topic, my adapter has been there a few months, along with the hose. One of these days the sender will get mounted to the end of the hose and I'll get my A pillar installed. One of these days - just not sure which one.
Old May 23, 2017 | 12:23 PM
Rod Jr.'s Avatar
Rod Jr.
Doesn't the original plug use a copper or aluminum washer ?
Old May 23, 2017 | 12:25 PM
Per4mance's Avatar
Per4mance
Nope,have it right here in my hand. It is a o ring.
Old May 23, 2017 | 02:19 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
That's what I have in mine. I had to find a Viton valve core for my Driven Diesel remote hose, it started leaking after a year or two.
Old May 23, 2017 | 02:30 PM
packagerjr's Avatar
packagerjr
Valve core for Schrader valve? For what that hose costs, I'd expect more than a year or two out of it. That's disappointing to hear. Guess I'll be on watch.
Old May 23, 2017 | 03:32 PM
jsm180's Avatar
jsm180
Mine works fine without a hose.
Old May 23, 2017 | 05:43 PM
lightflyer's Avatar
lightflyer
Care to share the sensor part number and other parts used? I am getting ready to have the blue spring mod done and adding this is also on the list.
Old May 23, 2017 | 06:23 PM
jsm180's Avatar
jsm180
Sure, Isspro sender/gauge ISPR17044 and adapter GS-FA_PS-6.0 is from glowshift.
Old May 27, 2017 | 09:33 AM
Rod Jr.'s Avatar
Rod Jr.
Any suggestions for a mechanical gauge with long hose for temporary use?
Jesser02EX
28
Jan 10, 2015 09:02 AM
mjlayton
Mar 15, 2013 08:59 AM
homesteader
Nov 29, 2010 09:01 AM
amgpro2
Jul 30, 2010 07:23 PM
wrangler76
Feb 4, 2008 10:22 PM
