boxlink, cleat {difficulty} **sigh**
Old Jan 7, 2018 | 08:26 PM
acelefty's Avatar
acelefty
I had one cleat that had a little extra plastic in the channel that slides up the bracket and I couldn't get it into place no matter how hard I pulled on it. Had to take a utility knife to that extra plastic and then it slid right into place.
Old Jan 7, 2018 | 10:28 PM
Martin6's Avatar
Martin6
Two of mine went in easy. The other two needed a little persuasion with a hammer and a block of wood.
Old Jan 8, 2018 | 11:13 AM
rick danger's Avatar
rick danger
Mine wont go in either. Threw them up on a shelf where they'll stay....just useless POS
Old Feb 2, 2018 | 01:26 PM
Texaswilliam's Avatar
Texaswilliam
Just tried to install mine. Got 2 out of the 4 in without an issue. The other two won't go in. Even with silicone spray and help from a rubber mallet. This is ridiculous.
Old Feb 2, 2018 | 01:33 PM
xxxsherpa's Avatar
xxxsherpa
Try what Acelefty said. I had to trim mine a couple of months ago for the same reason you guys are having.
Old Feb 2, 2018 | 01:37 PM
BlankSpace's Avatar
BlankSpace
I must be lucky...mine all went in one-handed and it took less than a minute to put them all on.
Old Feb 2, 2018 | 02:40 PM
KentuckySteve's Avatar
KentuckySteve
Taking Off?
Looks like there are lot's of answers for installing these cleats. But mine came installed, and I need to remove one. Is there a trick to this? i tried, but they are on there tight!! I can't budge them. Yes, I did unlock them.
Old Feb 2, 2018 | 06:00 PM
Peterk1w1's Avatar
Peterk1w1
Trailering
I had trouble too, I end up bending the back of the clip slightly to get it to turn into the bracket. I'm sure the spray on liner did not help any.
Old Feb 3, 2018 | 12:06 AM
NS70250's Avatar
NS70250
3 out of 4 of mine went in easy. The 4th was another story. A rubber mallet ended up doing the trick.
Old Feb 3, 2018 | 08:12 AM
spadoc's Avatar
spadoc
Temperature
A warm day makes it a lot easier too.
N2S3
Jan 30, 2018 10:05 AM
Servinghim
Mar 26, 2016 10:32 PM
RV_Tech
All Things Towing
15
Sep 12, 2013 02:19 PM
cfb2702
Jan 13, 2013 03:21 PM
msreb
Apr 23, 2008 08:14 PM
