Excursion liftgate - can it be done?
Old Jan 12, 2013 | 06:24 PM
cfb2702's Avatar
cfb2702
Had the dreaded happen. Manually locked the rear window liftgate lock and now can't get it to unlock.... Any ideas guys?
Old Jan 12, 2013 | 07:24 PM
VQT's Avatar
VQT
Did you work the key to lock/unlock several times (better yet many times) to see it free up? Other than that, search this forum, there is a post on how to work free the lock. And there is another to replace the whole thing
Old Jan 12, 2013 | 07:40 PM
sammie0126's Avatar
sammie0126
Take a small screwdriver and push the cover in a bit, take PB blaster or another lubricant spray with a tube nozzle stick it well into the lock and give it a really good spray. Then stick the key back in and wiggle it back and forth. Worked on mine.
Once you get it freed up the best long term key/lock lube IMO is PTFE Lube from Ford that is actually for the slip joint. I have used this on several sticky locks, coat the key and slide it in and out of the lock, I did this and those locks have remained stick free for 5 months now.
If the easy method doesn't work then give this thread a read
https://www.ford-trucks.com/forums/1...tch-locks.html
Old Jan 13, 2013 | 11:22 AM
double ott ex's Avatar
double ott ex
mine would only work with the key when I bought it. I had to take the latch mechanism out and clean the dirt and debris from the sliding portion of the electric lock actuator and greased it up good.
DOE
Old Jan 13, 2013 | 03:21 PM
cfb2702's Avatar
cfb2702
thanks
went out this morning while walking the dog and gave it one more try... lo and behold, it opened up... woo hoo, I am a happy camper. will get it apart next week and clean and lube it. Thank you sincerely for the advice....
sneltyr
Aug 6, 2012 09:59 AM
hoppy1118
Jun 30, 2012 10:59 PM
yachtdoc73
Aug 7, 2007 09:07 PM
keld
Feb 25, 2005 06:49 AM
Oval_obsessed
Nov 15, 2003 12:27 AM
