My 2006 CC Lariat has some peeled paint and rust right at the bottom corners of the rear doors. What's a good way to stop the rust before I spray over it? I'm having my fender flare area bedlined but don't want to do the entire rocker panels along with the doors because I like the one color look.
Get to your local auto paint supplier and have them fix you
up with of the stuff that is used to kill the rust and convert it.
I would tell you the name but I forget what the stuff is called.
You want the one that self neutralizes and does not need to be
washed off. That way if it seeps under anything your still oK.
