Rust Inhibitor
Old Jan 18, 2006 | 02:08 PM
lasracin's Avatar
lasracin
Rust Inhibitor
Has anyone worked with this stuff? Is it as good as advertised?
Old Jan 18, 2006 | 03:22 PM
garbz2's Avatar
garbz2
Like say POR 15?
Garbz
Old Jan 18, 2006 | 03:40 PM
lasracin's Avatar
lasracin
I am assuming. Had a friend tell me about this. He said to paint it on with a brush. Supposedly will stop rust and harden into a primer. Color will be black when hardened. After this is done, sand til' smooth.
Old Jan 18, 2006 | 03:46 PM
Winterbuoy's Avatar
Winterbuoy
Yep I need to know a good one also, mostly for inside the door jambs
Old Jan 18, 2006 | 04:00 PM
garbz2's Avatar
garbz2
you cant beat good ol POR 15 goolgle them and open an account... a little plastic ans dropped shipped to your door.
I do not recommend anything else.. I have used Master Products and find it inferior to POR...
Just remember its not UV stable and will chalk if not top coated.
best thing since sliced white bread.
Garbz
Old Jan 18, 2006 | 06:20 PM
Winterbuoy's Avatar
Winterbuoy
Thanks, I'll order some tonight. Read about it just now, sounds really good. Instructions are a bit scary
Old Jan 18, 2006 | 08:31 PM
nick65f100's Avatar
nick65f100
sprayed my frame with por15 and am very happy. though i would reccomend painting it on. I used an airless sprayer and despite my cleanup efforts my sprayer has not been the same since. Two other notes whatever it gets on it wont come off (wear gloves and long sleeved shirt), and dont skimp on the prep process. Follow their directions and youll be happy.
Old Jan 18, 2006 | 08:37 PM
6t6merc's Avatar
6t6merc
A little goes a long way. I suggest you prepare a bunch of stuff to paint, because once you put the top back on the can, it might be on there for good...
Eric
Old Jan 18, 2006 | 09:05 PM
jd_sylvia's Avatar
jd_sylvia
I bought my first can of POR15 at Vintage Ford and the salesman told me to put a couple of layers of cellophane on the top of the can before you seal the lid and it will open the next time. It works like a champ. I opened and closed the first can many times and never had a problem with it.
But het brush it on and it looks like it was sprayed.
jd
Old Jan 19, 2006 | 06:37 AM
garbz2's Avatar
garbz2
The healthy dose of instructions is to prevent your estates attourney for suing them LOL......"i didnt know this crap stayed on my skin forever" LOL
Garbz
Old Jan 19, 2006 | 06:52 AM
lasracin's Avatar
lasracin
I appreciate everyones comments. Would you recommend using the cleaner provided by them also or using your own home remedy? Again, thank you so much.
Chad
Old Jan 19, 2006 | 07:56 AM
garbz2's Avatar
garbz2
The marine clean is pretty strong stuff as well as the metal prep. It wirks as a system. expensive byt worth it.
Garbz
Old Jan 19, 2006 | 07:59 AM
lasracin's Avatar
lasracin
Garbz-
Thank you so much. Hope to post pics of this truck soon.
Chad
Old Jan 19, 2006 | 08:20 AM
berkad's Avatar
berkad
Garbz
So very true. I told my wife that I was going to start reading the instructions first, not after I'm finished.
Old Jan 19, 2006 | 01:08 PM
Ringo Fonebone's Avatar
Ringo Fonebone
If you sandblast your frame, make sure you get it REALLY clean in the hidden corners before you paint it with POR 15
Don't ask me why I know this
