Help me identify this ford engine please
Old May 17, 2017 | 09:31 AM
jrrando0653's Avatar
jrrando0653
Trying to sell this for my aunt....uncle died and this has been in the garage for a long time. 5 bolt valve covers, pictures attached. I think its from a truck but not sure. Any help is appreciated.
Old May 17, 2017 | 10:01 AM
lee's Avatar
lee
Hi,
I would guess from looking at the thermostat housing it's an FT.
You will need to measure the stroke to tell if 361 (3.5") or 391 (3.78").
Take care,
Old May 17, 2017 | 05:57 PM
85e150's Avatar
85e150
I searched that intake number and found a post from 2007 from Numberdummy.
Here is the line regarding the intake:
1. Intake manifold - C7TE9425G (also 7M15) Cannot find a cross reference # C4TZ-9424-H / 1964/72 330 M/D & 361
Here is the link to that thread:
https://www.ford-trucks.com/forums/6...-engine-2.html
Besides the t-stat another clue is the appearance of the exhaust crossovers going straight across the engine beside the carb.
It could be a 330 or 361. IIRC 391s were all 4bbl.
As such, it is worth the value of an FT core. The block could be used for an FE build, or, if you were really lucky, it might run with a mile clean up, fresh oil etc, and be a replacement engine for an older medium truck
Not sure what the transfer case looking item is, but there should be numbers and other id on it as well.
Old May 18, 2017 | 07:29 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yup, it's an FT - other than that, who knows. Need to either measure stroke or check crank numbers to tell what it really is.
fordnewbie1
Large Truck
21
Sep 9, 2011 01:06 AM
King_of_Norway
Jan 9, 2006 03:11 AM
Purely Ford
Nov 28, 2003 04:26 PM
Big Hands
May 13, 2003 02:26 PM
F100DREAM
Mar 7, 2003 05:28 PM
