Manual trans won't shift
Old May 14, 2017 | 10:29 PM
1Damnfastcoyote's Avatar
1Damnfastcoyote
hey peeps.
i gotta 93 f150 XL it has a 4.9L and a T18 borg Werner trans.
i replaced the clutch,throw out bearing, pressure plate and pilot bearing and after reinstalling trans I am unable to go through my gears.
if truck is off I can shift into some gears sometimes but not without a lot of resistance. Also some gears will let me in easy, then fight me as I try to back into neutral.
truck starts right up but if I start in neutral I can't shift into any gears and get a lot of grinding when I try to put it in gear.
if I start in gear it drives in the gear but I have to force back into neutral.
Old May 15, 2017 | 07:52 AM
The Frenchtown Flyer's Avatar
Bleed clutch?
Clutch disc in backwards?
Bellhousing dowel alignment off?
Wear ridge on TO Pilot sleeve?
Old May 15, 2017 | 10:04 AM
Harte3's Avatar
Harte3
https://www.ford-trucks.com/forums/forum40/
https://www.ford-trucks.com/forums/forum69/
Try posting in those Forums...
skyler_estes
Jan 14, 2020 10:10 PM
1Damnfastcoyote
May 17, 2017 06:03 PM
ctrout
Nov 20, 2006 09:05 AM
kbddbd
Jun 5, 2005 06:20 PM
the tank
Apr 16, 2004 10:40 AM
