Cold Crank NO start. frustrating
I have an 02 f250 230,000, first 7.3. I've owned it since Oct and put less than 6,000 miles on it. I have another cold crank no start. New glow plugs and Glow plug relay last weekend. Worked fine that weekend. It sat all week, then crank no start fri night, it was like 70 degrees for the high that day. Plugged it in over night and it started. Did not fire right up cranked it for a couple seconds. I drove it all day, started every time. Valve covers have 5,000 miles on them. Fuel Filter heater fuse not blown. But don't know how to check it for sure. And don't know where to go with it from here. Getting frustrated with crank no starts. No troubles found.
Thoughts?
Thoughts?
Check the fuel bowl and see if it is filling up. Check the high pressure oil pump for oil. These are two things that could effect starting. There is also a thread the addresses all the issues of no start if you do a search. Someone will be in here soon that probably has that thread saved.
kc0ti1002
1999 to 2016 Super Duty
11-05-2010 10:42 AM
Renegade361
30
10-16-2006 10:11 PM
