Cold Crank NO start. frustrating
Old 05-14-2017, 01:20 AM
Cowboy308's Avatar
Cowboy308
Cowboy308 is offline
I have an 02 f250 230,000, first 7.3. I've owned it since Oct and put less than 6,000 miles on it. I have another cold crank no start. New glow plugs and Glow plug relay last weekend. Worked fine that weekend. It sat all week, then crank no start fri night, it was like 70 degrees for the high that day. Plugged it in over night and it started. Did not fire right up cranked it for a couple seconds. I drove it all day, started every time. Valve covers have 5,000 miles on them. Fuel Filter heater fuse not blown. But don't know how to check it for sure. And don't know where to go with it from here. Getting frustrated with crank no starts. No troubles found.
Thoughts?
Old 05-14-2017, 05:23 AM
Whitey Ford's Avatar
Whitey Ford
Whitey Ford is offline
FTE-Spread The Knowledge
Check the fuel bowl and see if it is filling up. Check the high pressure oil pump for oil. These are two things that could effect starting. There is also a thread the addresses all the issues of no start if you do a search. Someone will be in here soon that probably has that thread saved.
Old 05-14-2017, 08:09 AM
Tugly's Avatar
Tugly
Tugly is offline
You will want to use the non-mobile site to see the links in my signature. Once you are on the full site and reading this, you can link to a ton of information in my sig.
Rivieraman71
1999 to 2016 Super Duty
04-07-2019 09:10 PM
slim613
01-12-2016 10:39 AM
TinyWonder
11-08-2012 09:01 PM
kc0ti1002
11-05-2010 10:42 AM
Renegade361
30
10-16-2006 10:11 PM
Quick Reply: Cold Crank NO start. frustrating
