Neutral safety switch linkage install
Old Jan 22, 2006 | 10:47 AM
Chromepro's Avatar
Chromepro
I have a 68 f100, 2x4, 360, auto C-6, that I just installed a 79 column and Bendix to Saginaw steering system change-over into. Now must complete the wiring and install a neutral safety switch. I'm going to shave grooves into the tranny linkage for the NSS with a dremel, but wondered if anyone has ever done this before and has any recommendations? I would rather have the correct linkage, but am unable to find the necessary parts currently. Hopefully this setup will work until then. I purchased a new NSS, but haven't any idea if it's in "Park" or somewhere else, so I will wire it first to try before installation. I'm still matching wires to complete the column and would appreciate any assistance with that as well. Thank you for your help!
Old Jan 22, 2006 | 05:39 PM
phat56's Avatar
phat56
I used a 76 column and the switch was on the base of the column. I guessing the switch is on the x-mission on yours? I guess I can't help you if that's the case. Good luck
Old Jan 22, 2006 | 08:54 PM
Chromepro's Avatar
Chromepro
After 78 they went to the tranny linkage. Finished the wiring and now the fun part!
Cobra1993ky
Nov 3, 2013 12:05 PM
shruck
19
Mar 4, 2013 10:24 PM
m000996
Electrical Systems/Wiring
Mar 31, 2007 02:36 PM
Dads79
Jun 21, 2006 04:13 PM
