I am not an ace mechanic but I have old truck I just bought and I love it.. Today the shaft of the distributor must have broken or something that is preventing the distributor contact from turning. It was on there when I bought the truck and obviously new. The box for new one came with the truck with the old distributor inside. The box was for a cheap advanced auto special. The old one seemed to be intact. Not sure why he changed it.
I pulled the valve cover to see if the valves were working and they are so my conclusion is the distributor shaft is broke some way.
Can anyone point me too or help with an outline of the process for putting in a "Blank" distributor. I am having trouble imaging what to do.
I assume set the motor for TDC point the distributor at the #1 plug contact on the cap. Timing the distributor with a timing light to 8 degrees BTDC as per the valve cover sticker with the specs. But I just wanted to make sure or hear from some experienced in case I am missing something.
'Might have sheared the oil pump shaft, locked up the oil pump, broke the pin securing the dizzy gear which meshes with the camshaft, or whupped the dizzy gear itself.
I'd rotate the crank by hand to see if it spins the rotor. Post your result.
Nope didn't spin. The distributor runs off the oil pump? The truck came with paper work he had new FORD short block put in it 4 years ago with 15000+- miles on it.
The thing is the distributor doesn't spin by hand, but doesn't manually (Now we know) and doesn't spin with the starter.
I know its not the timing chain or the cam would not move the valve and the valves are moving. I just want to replace the distributor but I am not sure how to find the timing once I do. I just want to make sure if I pull the distributor I can put it back so that the timing is within reason of the distributor adjustment. Follow me?
If it more than the distributor I'll buy a full engine to put in.
Somebody here can walk you through "stabbing" a new distributor, don't worry about that too much. Follow the procedure carefully and it will fire up on the first try.
The real question is what broke, and why. The roll pin for example, that secures the gear on the distributor is kind of a sacrificial deal. It sometimes shears off, instead of really lunching something important but, it shouldn't happen.
When you pull the distributor make sure your #1 cylinder is TDC on the compression stroke. There's another #1 TDC but that's on the exhaust stroke.
Mark the cap where #1 is...should have a mark there anyway and note which direction the rotor is pointing. I think it's ~ 1200 hours, looking down at it from the front...on the M Block anyway... IF your vacuum advance can's nipple is facing front.....don't know what engine you have.
After it's pulled, inspect the gear....it shouldn't move when turned if you're holding the rotor. If it does, the shear pin (or roll pin) is pooched.
Then, tape a 6 point 0.25" socket to an extension...slide it down the distributor hole and engage the oil pump drive shaft. Try turning it CCW....feel for resistance and, if the valve covers are off, watch for oil slithering up the pushrods, through the rockers and down the valve springs. This will tell you if the oil pump shaft is still good.
If the driveshaft is pooned, does this mean you'd buy a new engine? Shooot, if so, I have part of the Brooklyn Bridge to sell ya...hehehe.
Ya I agree I want to know why. He obviously put a new one on and maybe its another problem causing this one. I just wasn't sure how to "Stab" a new distributor in. I just wanted to make sure I was thinking right. Its a blond thing..
It has a stock 302 sorry I didn't mention that.
I appreciate the walk through. Those are details I was looking for.
Shouldn't turning the engine over push oil through rocker arms? I was was pretty sure it was but I'll recruit some help tomorrow and make sure. Then I'll update.
No problems with the blond thing...Elvis was really a blond... and as stated before, they'll be plenty of people here to help walk you through the installation.
I don't want to buy an engine..LOL...Or a bridge.
Thanks again.
Matt
You're welcome. Not interested in a bridge, eh?
Actually, turning an engine over by hand won't get the distributor (and oil pump) turning fast enough to pump any oil. A 1/2" electric drill will be put to test trying to turn the oil pump shaft fast enough to get the blood circulating. ....A note on that - I don't believe a 3/8" drill has the poop to turn the shaft...I always use an 1/2."
Measure any replacement/rebuilt distributor for correct dimensions, this is sometimes overlooked. (From mounting boss to end of distributor shaft) You get what you pay for, if you're lucky.
Does it have a high output oil pump or something like that? Remember the distributor drives the oil pump.
Read up online on V8 distributors and engine tuning, timing, and vacuum advance there is more information available at your fingertips these days than ever before.
I would check why the gear striped the pin holding it to the shaft. I had this happen on a rebuild that I had done. The valve stem seals were getting crushed by the retainers hitting them from being machined wrong. The seals get in the oil pan then through the oil pump screen into the pump that stops for a second and shears the pin on the gear. Clean the oil pan replace the oil pump & pick up screen.
Well I just speculatin' that the roll pin shear was the problem. A what if maybe probably. Not sure that's what happened.
