Numeric Values over Gauges
Old Apr 29, 2017 | 11:29 PM
Dysert's Avatar
Dysert
This screen clip is from the Fast Lane Truck Ike Gauntlet test of the 2017 f250 SD King Ranch. If you look closely you will see numeric values displayed above the transmission temp and water temp. When do these show up? My truck does not display the numeric values. This is at 7:26 in the video.
Old Apr 29, 2017 | 11:35 PM
Dysert's Avatar
Dysert
Do they display in the Tow/haul mode?
Old Apr 29, 2017 | 11:46 PM
wb6anp's Avatar
wb6anp
We may be able to do this with the Forscan software one it is updated so we can write to the IPC.
Old Apr 29, 2017 | 11:57 PM
MJR777's Avatar
MJR777
I think it is in the tow haul mode only where that is displayed -- now I need to go double check
Old Apr 30, 2017 | 06:29 AM
System's Avatar
System
Prolocutor
Not tow/haul related. They show up over normal daily driving operating temps and disappear again when the temp drops below the trigger threshold. For the coolant I believe it's 215. Not sure on the tranny. As said above, once Forscan can write to the IPC, we should be able to enable them all the time like can be done on the 150's...
Old May 7, 2017 | 10:20 PM
MJR777's Avatar
MJR777
Since the codes are known (Forscan spreadsheet) to enable this all the time can we not have our dealer do that (I had mine add the DPF % screen) to the IPC?
Old May 8, 2017 | 05:32 AM
System's Avatar
System
Prolocutor
I bet they could but knowing where to look with IDS might be challenging for them.
Afrnd2all
Nov 22, 2017 09:31 AM
oh2sd
Nov 9, 2014 06:53 AM
gregrutter
Jun 2, 2007 10:57 AM
junior323
Mar 27, 2007 06:40 PM
jgray
Oct 8, 2004 10:12 AM
