ticking noise
Old May 7, 2017 | 09:49 AM
junorris's Avatar
junorris
ticking noise
I noticed a ticking noise yesterday in the vicinity of directly under engine when at idle and cold....seems to go away when truck is driven and hot so not metal expanding etc......I know about the regen causing noises but would have thought that would be further back of the truck around the exhaust components,,,anyone have any ideas?
Old May 7, 2017 | 10:03 AM
shortride's Avatar
shortride
Is it a diesel?
Old May 7, 2017 | 10:33 AM
alloro's Avatar
alloro
That is an incorrect assumption. An exhaust leak will tick and it will go away or at least get quieter as the head and manifold heat up and expand...closing the gap between the two.
Old May 7, 2017 | 11:14 AM
junorris's Avatar
junorris
Yes . 2017 6.7 diesel ..did not suspect exhaust leak...
Old May 7, 2017 | 02:42 PM
ssoundwave's Avatar
ssoundwave
Sounds like the joker put a clock bomb under the truck, just kick down on the floor bored and it will fall off!
Old May 7, 2017 | 09:40 PM
FOUNTAIN 1's Avatar
FOUNTAIN 1
ford says its normal .. my duelly sounds great .. king ranch rattles like hell .. some say add extra court of oil .. it helped a little . little . sounds horrendous at drive throughs
Old May 7, 2017 | 11:46 PM
Crazy03's Avatar
Crazy03
I heard the same thing from mine the other day, goes away after you drive but very noticeable and annoying. I was going to take it in and have them look at it but seems as if they/Ford are doing nothing about it
Old May 8, 2017 | 04:56 AM
junorris's Avatar
junorris
yea it is odd it just started doing it 3000 miles on it.......just curious if others here have had this happen...anyway won't worry too much about it.
Old May 8, 2017 | 05:19 AM
shortride's Avatar
shortride
I'm almost totally deaf and I can hear a ticking but I wrote it off as one of the normal sounds of a diesel engine. Some sounds can be telegraphed to sound like it's coming from a different location than where it is actually being created.
Old May 8, 2017 | 06:30 AM
junorris's Avatar
junorris
I know this is dated but perhaps the culprit......
6.7L DIESEL—TICK/TAP NOISE AT IDLE TSB 10-19-2
FORD:
2011 F-250,
F-350"><span style=F-350" /> F-350">F-350
, F-450, F-550
ISSUE Dealers should not attempt to compare any
Some 6.7L diesel equipped vehicles may exhibit a customer vehicles exhibiting this noise with other
ticking noise at idle after an engine oil change. It is similar vehicles as the noise is different from vehicle
often referred to as Typewriter Noise because of its to vehicle and this may lead to the incorrect
similarity to the sound of random typing on a conclusion that the vehicle has a condition.
mechanical typewriter. Customers may report that Typewriter Noise is a normal operating
when near a building, wall or drive through window, characteristic of this diesel engine. This noise has
that this noise can be heard from inside the cab. no short or long term effects on the engine. Do not
attempt repairs to eliminate this noise. This noise is
ACTION characteristic of the 6.7L diesel engine and will
Follow the Service Information to inform the typically cease or diminish significantly within the oil
customer of the characteristic. change maintenance interval.
SERVICE INFORMATION Refer to vehicle Owner Guides and Maintenance
Guides for approved engine oil viscosities and
The relationship between the oil film, crankshaft usage information. Use of different oil viscosities will
journals, bearing inserts and engine cylinder block not eliminate this noise and is not recommended.
produces a sound that is heard as a ticking noise. Customers should be informed that these conditions
The overall noise reduction in engines produced do not affect engine durability and no repairs are
today makes this noise seem new when, in fact, it necessary.
was present in prior model year vehicles, but
masked by other noises in the past. Because the WARRANTY STATUS: Information Only - Not
6.7L diesel engine includes a number of design Warrantable
improvements to reduce diesel engine noise,
Typewriter Noise can be more noticeable than on
previous products. Typewriter Noise is not
detrimental to engine function or durability. Other
manufacturers of diesel engines have reported the
presence of this condition for a number of years.
Build tolerance stack-up from engine to engine
contributes to perceived differences in noise
intensity. When engine temperatures reach 150 °F
(65 °C) or higher, (from engine idle up to
approximately 1700 RPM’s), this noise can typically
be heard at the front wheel well and is often
isolated to the transmission bell housing or oil pan
area.
buono26
Jan 28, 2020 12:29 PM
stowbilly96
Jan 14, 2016 06:36 PM
ffdemoss
Oct 18, 2011 11:26 AM
SHOpar
Aug 12, 2010 07:19 PM
sls
13
Jan 28, 2007 03:40 PM
