2004 f150 wouldn't start now won't shut off
Hey everybody I'm a new user. But I came here because I have looked everywhere and can't find anything exactly like I have going on. I need help asap it's my daily and I can't figure out what's going on. But first what happened is I went to get in the truck I opened the door and the gauges and blower motor came on by itself like the ignition is in the on position. I put the key in the ignition and the truck didn't do anything. No crank or anything and I did notice the anti theft light blinking really fast. I unplugged the battery and plugged it back up then the truck started but I went to shut it off and pulled the key out the ignition and truck stayed running. But also the blower in the truck and the gauges are still staying on. People keep saying it's my key but why would the stuff cut on by itself inside the truck when I just opened the door? If anybody has seen this before please let me know what I need to do thanks.
if you see any dampness on the floor or carpet, or if this tends to happen after it rains, then you might guess the window leaks and GEM is wet ( under dash by steering wheel).... another option is to remove the GEM and look inside it to see if there is corrosion..... The ignition switch with the wires is what we are talking about.. the actual "key" lock would not have much effect. You can not change the key, or the pickup ring ( metallic donut) around the key as they are matched to the PATS startup system.
You say it "acts like the key switch is on"........... maybe a good test would be to unplug the harness at the ignition switch, then put the battery cable back on.. If truck does not start cranking and start, then the switch must be part of the problem... if the truck auto starts on its own with the ignition switch unplugged, then you have eliminated the switch as the problem, and need to look further.
RBerry9511
02-07-2020 04:31 PM
quakerj
11-03-2017 08:04 PM
