A newbie question about Boost...
Old May 2, 2017 | 12:24 PM
  #31
Bonanza35's Avatar
Bonanza35
I'm sure it been posted that the tune can keep over boost code away but still can damage the map sensor. I believe Tugly posted this. Just to put it out there again.
Old May 2, 2017 | 01:05 PM
  #32
ExPACamper's Avatar
ExPACamper
This is the first time I've heard it could DAMAGE the MAP sensor???
Old May 2, 2017 | 01:25 PM
  #33
Bonanza35's Avatar
Bonanza35
Ask Rich. He changed his out because he said boosting to high damaged it. So he since installed the fooler from Clay.
Old May 2, 2017 | 05:35 PM
  #34
Stewart_H's Avatar
Stewart_H
Originally Posted by Walleye Hunter
If that's what you call them, I have experienced them. Thread title is bold, Stewart_H shows as last poster yet when I click on the title his post does not show up. Back to forum main page, reload and same thing. I thought maybe it was just me.
That's happened with a post of mine?
Heh heh heh....does that mean a new avatar for me?
No...I'd have to change my first name to something that starts with a "P" if I did that. No bueno.
Stewart
Old May 2, 2017 | 06:07 PM
  #35
Walleye Hunter's Avatar
Walleye Hunter
Stewart
I don't think it was yours, your member name was right there so I used it as an example.
Old May 3, 2017 | 07:30 AM
  #36
Tugly's Avatar
Tugly
Originally Posted by ExPACamper
...Of course, you'd want to crank your wastegate spring a little tighter to hold the higher boost or it will pop regardless of the WG solenoid command.
I didn't see that mentioned above?
Thanks for reminding me, I fixed it.
Yeah... 160 HP bump on a bigger turbo with all the air mods did the MAP sensor in. I now have to run a separate analog boost gauge to see the upper limits of boost and I protect the MAP sensor with a fooler, but I still get all my detailed boost readings from the OBDII port.
I've heard of one other person who lost a MAP sensor, but I don't know the circumstances.
carguy3j
Sep 18, 2017 06:54 AM
dieselsmoker
Apr 9, 2011 11:29 AM
bad12jr
Jun 11, 2010 04:07 PM
Schmitty133
Feb 11, 2009 09:13 AM
Turf Truck
Feb 6, 2004 11:15 AM
