A newbie question about Boost...
A complete one shot clarification of this, how the redline works, defueling etc., would be fantastic.
And no offense to actual newbies lurking about!
Clearly something's amiss here. If MAP stands for Manifold Absolute Pressure - which I believe is true - then either CousinCarl is located in some weird section of the universe, or his gauge is mislabeled. The Absolute part means it can NEVER be negative, so I would take this gauge to be a BOOST gauge, and therefore showing MAP - BARO. In which case his truck is very similar to mine, maxing about 23psia, unless it does reach that 30 mark.
I'm constantly considering updating to the late '99 setup and going for some better performance, but I really need to understand the baseline stuff first. Hence your truck **** posts are truly annoying as having a spare 7.3 to rebuild slowly into something reasonable and new and reliable is the kind of thing I would really enjoy doing.
I'm no expert on the other stuff you asked about, so I will let others handle it.
I'm new to Torque Pro. Just started messing with it actually. That reading is at idle there. Since I just started monitoring it idk what normal is for this truck. I plan to perform a boost leak test and make sure I'm not losing any anywhere. That PID is listed as FORD specific Boost and when I placed it on the page it labeled it MAP automatically. There is another Boost gauge listed in the PIDs that puts it in Hg/in I believe on default. Sometimes its labeled boost sometimes it labels it Vacuum. When I convert that one to psi in the app, it spits out nearly the same numbers as the MAP gauge but at a delayed rate it seems to me so I got rid of it and kept the MAP one. I don't claim to fully understand all of this myself, so if I have done something in error, please let me know.
Odd that your default TP MAP gauge reads actual boost then, as mine reads in absolute. That check is done with the engine off, as the Exhaust Backpressure (EPB) sensor, the internal PCM Barometer (BARO) and the MAP should all read the same absolute air pressure, or ~14.7psia depending upon altitude.
And yes Mark, by red line, I meant that little tube that serves the wastegate. I understand that as MAP increases above a set pressure, the control will open the wastegate and dump exhaust to limit MAP to some pressure, but I don't know whether there's any adjustment that can be made - beyond plugging it. And then there's the whole PCM defueling thingy.
I'd love a nice story telling how these folks get along and play nice with each other, and how the evil PMS villain in us all tries to fool them into blowing up our engines...
MAP - Manifold Absolute Pressure... the word "absolute" is right there in the sensor name. Absolute manifold pressure is the pressure of the atmosphere, plus whatever is added/subtracted by any pressure-enhancing devices (turbo or blower) and the engine draw at the intake manifold. At idle, there is not any real pressure on the exhaust side - so the turbo is freewheeling (more or less). Without any significant push from the turbo, the engine (which is a very big piston air compressor) is sucking air in, pulling the MAP reading down a little.
Boost - this is MAP minus BARO, so you can look directly at what the engine/turbo is doing to the intake manifold pressure. Many people just want the boost number when they glance for that 1/2 second at the gauge. They don't want to take time out for a math quiz while at WOT... calculating their current barometric pressure to work out how the turbo is doing. There actually are laws against this in Washington state - calling it "distracted driving"... but I digress.
Defueling - two things have to happen:
- You need to exceed 22 PSI boost (MAP minus BARO)
- You need to cross over 2800 RPMs
OK... 22 PSI is the number, but how does one exceed 22 PSI on stock tuning with stock injectors and turbo? The graph above is from a vehicle that did exactly that... so it's not fake news or netlore. The red tube to the top of the turbo carries some of the boost pressure to a valve control. That valve is the wastegate, which allows the exhaust backpressure to bleed off - stealing away the driving force behind your turbo. The red tube has air pressure in it much more than many realize, constantly allowing at least a little backpressure to bleed off at throttle far less than wide open. If you cap the red tube off, you block a little boost from escaping from the tube, but more importantly - you prevent a wastegate open command from reaching the wastegate.
Now... here's where I don't have direct experience, because my WG actuator was modified before I bought the truck. I have heard of the "7-turn" mod, where you spin the actuator threads out seven turns to push harder on the wastegate. You can then get full exhaust backpressure to push the turbo - driving your boost up to readings you didn't know you could do. It's not akin to donning rocket boots, but it's like taking off the galoshes and putting on some running shoes. For those concerned - we don't really worry about exceeding the turbo limits until we surpass 26 PSI (tuning territory).
OK... that allows more pressure, but it doesn't necessarily get you to the mystical defueling zone. I have learned that our stock exhaust is pretty much tuned for the limits placed on our beloved 7.3L by the Ford engineers. The pipe allows 20 PSI boost just fine, but anything above that and the pipe protests. Ever try to exhale through one of those coffee stirring straws? It can be done, but it's much more productive to get a Slurpee straw. The 4" lets the exhaust out of the turbo easier and is a huge help for those seeking boost values above 20 PSI. The higher the boost goal, the more one benefits from a bigger tube.
Intake - our stocker doesn't suck... it instead allows the turbo to draw anything except filtered air. Moving to a bigger/better intake is like trading in our coffee stirring straw for a Slurpee straw before drawing from a beverage cup. That was my first step on the truck with the graph above - a Ford AIS on a stock truck. Group that with a bigger exhaust and red line mod, and you find defueling to be your next hurdle. This is where the boost fooler comes in.
Boost fooler - there are a few forms of this, the PO installed a zener diode on the MAP signal line as a cheap boost fooler, but this really messed with the performance of the truck - so out it came.
I instead used the type that is a pressure regulator placed on the air line feeding the MAP sensor. The MAP sensor sees only the boost pressure allowed by the boost fooler, and the regulator never lets the boost pressure to the sensor reach 22 PSI. You can see my boost fooler in the very upper-left corner.
If anybody is wondering - these are the most harmless mods you can perform on a stock truck. If I saw these as the only mods on a pristine Superduty with a 7.3L on the used market, I wouldn't hesitate to buy it because the mods are so conservative and they augment reliability as well as performance.
In fact, here you go.
https://www.ford-trucks.com/forums/s...rchid=24745462
Stewart
