window seals
Old Apr 25, 2017 | 04:12 PM
rj1983's Avatar
rj1983
window seals
Been looking to replace the window seals, which I believe could be called the window scrappers on my '89 f150. Ones currently in there are cracked and breaking up causing the window to get jammed up at times when they break apart.
Has anyone replaced these before? Does the window glass need to come out and are there any special tools I need before I go and pull the door trims off?
Old Apr 25, 2017 | 05:41 PM
Fastback460's Avatar
Fastback460
I haven't had mine apart in awhile, but IIRC all you need a Phillips screwdriver to get the door panel off, and then you can pull off the metal clips that hold the scrapers in place.
You shouldn't need to take the glass out, just lower the window all the way
Old Apr 25, 2017 | 08:57 PM
rj1983's Avatar
rj1983
Ok, cheers mate.
Old Apr 26, 2017 | 01:31 AM
GreenMtnMan's Avatar
GreenMtnMan
I replaced the ones on my 1987 F250. They come off by sticking a small screwdriver between the wiper and door to snap the clips out of their slots. I bought mine from LMC truck, they didn't fit very well. I had to do some careful trimming.
Old Apr 26, 2017 | 02:35 AM
rj1983's Avatar
rj1983
ok, no worries. I was going to get mine through RockAuto, hopefully they are a better fit.
Old May 2, 2017 | 06:30 AM
Clinton Thomas's Avatar
Clinton Thomas
Let us know how they fit. I need to replace them on my 95 F150.
Old May 2, 2017 | 03:54 PM
rj1983's Avatar
rj1983
Ok, will let you know. Ill be ordering some from rockauto just as soon as they get some other parts in stock that Im waiting on.
Old May 2, 2017 | 07:35 PM
sandymane's Avatar
sandymane
I just installed mine from Rock Auto and the fit was perfect. Plus I believe there was more felt on the RA than stock. Easy to install. I pulled the door panels and painted my interior door handles while I had em off.
Old May 3, 2017 | 03:29 AM
Clinton Thomas
Good to know. I'll have to check Rock Auto. LMC Truck sells a set that includes seals for both doors for $60 but I've never ordered from them before. Rock Auto is pretty dependable. Just gotta watch their shipping charges if you're ordering several items at once.
Dutter
Jul 25, 2010 07:45 PM
Diesel_Brad
Aug 23, 2009 09:04 PM
Cap'n Tea Bag
Nov 10, 2005 03:41 PM
Olpapa
Oct 13, 2004 09:14 AM
burlii
Aug 26, 2002 07:36 AM
