Dropped bolt into motor
Old Jul 26, 2023 | 07:18 AM
Walleye Hunter's Avatar
Walleye Hunter
Deleted post.
It looks edited to me.
Old Jul 26, 2023 | 07:21 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Of course now I’m having to shave down my injector hold down brackets due to arp head studs /: .close to the finish line though.
That's weird. All the sets of ARPs I did on a 7.3L had four shorter studs per side included just for that reason.
Old Jul 26, 2023 | 07:52 AM
FordTruckNoob's Avatar
FordTruckNoob
My my. You’re a smart feller aintcha?
Old Jul 26, 2023 | 08:05 AM
Walleye Hunter
Have you moved yet? I hear it's nice and toasty out in Vegas.
Old Jul 26, 2023 | 09:28 AM
FordTruckNoob
Not yet but I will soon.
Old Jul 27, 2023 | 12:47 AM
14WIDEZ_PAPI's Avatar
14WIDEZ_PAPI
Trailering
Injector hold down bracket
The kit did include 8 shorter studs 4 each side. Talked to an old head 7.3L guy and I geuss arp sometimes is like fractions of mm “or whatever small measurement” too long and it holds the bracket up from hopping over and sliding down. I was able to loosen the bolt put injector in and then tighten back down to 10 ft pounds. I did shave bracket slightly when I’d go to tighten down it would get really tight against the stud. I double checked everything stud length was the only thing I could find wrong. But there was no debris in the hole threads were freshly cleaned. No matter what the stud would protrude. I didn’t want to not be able to take the stud out so I didn’t trim that I just shaved the tip of the hold down bracket .
Also found out the hard way that you need to replaces the hold down bolts when you do injectors. snapped one of them /:
that was a different injector than the one I’m having trouble with though.
I don’t know though this is my first diesel build kinda just figuring it out as I go.
any advice would be appreciated.
trucks almost back together I’m doing the wiring harness and iraite fuel system with a sump at the moment.
thx for responding so fast!
miihere24
Jun 15, 2013 01:42 PM
eriklane
21
Sep 27, 2010 08:41 PM
Oldnslofly
Aug 2, 2009 09:51 PM
reeds101
Jun 25, 2009 07:00 PM
fordguy300
Aug 5, 2008 08:44 AM
