Speedo problems
Old Apr 23, 2017 | 02:39 PM
LIQUID8's Avatar
LIQUID8
Speedo problems
I have been having issues with my speedometer bouncing while driving. First of all my speedo is registering about 15 mph slower than it should be. On top of that it bounces around. I also recently noticed my odometer is substantially off. I replaced the speedometer cable hoping it would help but I see no change. Is this likely because of old faulty gauges or is there something else that could be causing my issues? Thanks for any help.
Old Apr 23, 2017 | 03:04 PM
Ford_Six's Avatar
Ford_Six
Taller gearing will change the reading. You can get a new gear from Ford or a speedometer company. I have used Tacoma Speedometer a few times with good results.
Here's a calculator for which gear you need
Speedometer Gear Calculator and Charts - TCI® Auto
One of the Ford parts guys should be able to translate tooth count into the color scheme that Ford used.
Old Apr 24, 2017 | 05:58 PM
JEFFFAFA's Avatar
JEFFFAFA
2X Jared. I think the problem is one or both of the speedo gears. Either the "drive" gear in the tranny or the "driven" gear end of the speedo cable. Remove the cable from the tranny. Reach in that hole to feel across the top of the speedo drive gear's teeth. The teeth should feel flat across. If the center of those teeth are worn out they will feel "dished". Dished equals bad gear. I would need color of the gear or number of teeth, 4X2 or 4X4, and which tranny you have to look up the drive gear.
On the "driven" gear, while you have that cable out of the tranny look at the color or count the number of teeth that gear is for me. And 4X4, A/T, or M/T? Each tooth equals 3-5 MPH. So it sounds like you need a driven gear with 4 less teeth than you have now.
Old May 30, 2017 | 02:12 PM
LIQUID8's Avatar
LIQUID8
After removing the cable I found out the cable had fallen against the exhaust and melted the cable. New cable installed and working.
Old May 31, 2017 | 05:38 PM
JEFFFAFA's Avatar
JEFFFAFA
Cool. Glad to hear it's fixed.
Old May 8, 2018 | 12:26 AM
David+Don's Avatar
David+Don
FTE Content Contributor
Hey - did you find your speedo was ticking as well when this happened? Mine just started doing it.
Thanks
Ironmike86
Feb 20, 2014 02:02 PM
blupkes
Jun 30, 2013 08:24 PM
Tomget
Feb 2, 2013 08:54 PM
Pete Roberts
Feb 14, 2011 11:52 AM
Chuck88
Aug 18, 2006 04:29 PM
