Speedometer isn't working.
Old Jun 30, 2013 | 02:03 PM
blupkes's Avatar
blupkes
I've replaced the speedometer cable in my 1983 Ford F250 300CID 4 speed transmission, and it did not fix the problem. The cable is not spinning when I drive, so I think it is an issue with the speedometer driven gear. I've done some research and have discovered there are four different gears with different teeth counts. Does anybody know what the correct speedometer driven gear tooth count is? Any help would be appreciated. My fuel gauges aren't working in either tank too. Help with that would be great. Thanks.
Old Jun 30, 2013 | 02:50 PM
Franklin2's Avatar
Franklin2
Go ahead and pull the cable off the tranny, take the keeper bolt out, and pull the little housing out of the tranny that the speedo cable attached to. You will see the plastic gear on the end. You can then determine if it's stripped or not, and the color. The color is what you need to know, or if there any teeth left, you can count the teeth.
Old Jun 30, 2013 | 08:24 PM
blupkes's Avatar
blupkes
Thanks.
I've done that, and it's pink and it seems to be a little damaged. I wasn't sure if that was the correct one or not. I'll get a new one and see if that fixes it. Thanks.
LIQUID8
May 8, 2018 12:26 AM
Shiveron
Sep 30, 2014 06:44 AM
codycapek
Feb 19, 2013 02:03 PM
Pete Roberts
Feb 14, 2011 11:52 AM
onemanchan82
Jun 13, 2003 08:04 AM
