Sponsored by: Real Truck
Truck is dead
Old Apr 21, 2017 | 09:00 AM
navnik531's Avatar
navnik531
Truck is dead
Hey guys, I'm a fairly new member, but have found a ton of useful information to help me work on my own truck. A good friend of mine recently had a large issue with his current truck that I am going to be working on this weekend.
His 2005 F250 (I believe is a 5.7) quit working the other day all together. Nothing at all works when the key is turned. No clicking no lights no nothing. The battery was tested and is in good working order, so I have some ideas, but am still unsure of what may cause this exactly. Hoping some one here may have a better grasp than I do of what may be causing this issue. Thanks all for your time and consideration!
Old Apr 21, 2017 | 09:08 AM
Copper.Farm's Avatar
Copper.Farm
Welcome to FTE.
Old Apr 21, 2017 | 09:09 AM
kcducttaper's Avatar
kcducttaper
I don't believe Ford makes a 5.7. If it's a gasser, it might be the 5.4.
Off the top of my head, it sounds like it could be a bad battery connection, master fuse, or ignition switch/relay. Do normal "non-ignition" electrical things work when the ignition is switched off? Headlights, dome lights, horn, etc?
Old Apr 21, 2017 | 10:08 AM
navnik531's Avatar
navnik531
It is gas so it must be a 5.4 then. Absolutely nothing works even if the ignition is off.
Old Apr 21, 2017 | 12:06 PM
phillips91's Avatar
phillips91
Welcome to fte. The first thing i would check is the battery connection. I've got an expedition that did the same thing because one of the terminals didn'tnt make a good connection.
Old Apr 21, 2017 | 12:08 PM
kcducttaper
Under the assumption that nothing electrical at all works, the good news is there's not all that much electrical-wise to check between the battery and all of the electrics. Just check all your battery connections real good, grab a volt mater and make sure it's grounded solid, and follow your battery wires to see where you lose voltage.
Old Apr 21, 2017 | 12:40 PM
navnik531's Avatar
navnik531
Alright thank you guys, I will do just that when I get there and post back if it fixes the issue. Thanks again!
Old Apr 24, 2017 | 08:33 AM
Mike1's Avatar
Mike1
On my 03 I lost all power also, I traced the + cable back over to the drivers side near the middle area for the fender there was a black plastic junction box. When I opened that, the lug on the battery cable had broken from corrosion and rust.
Old Apr 24, 2017 | 03:24 PM
speakerfritz's Avatar
speakerfritz
see if it starts in neutral. make sure you are not on a hill.
Christopher Gott
Apr 16, 2016 12:35 PM
eric1793
Jun 23, 2011 08:10 PM
MBBCop
Electrical Systems/Wiring
13
Feb 17, 2007 01:57 PM
Polkat
Nov 2, 2002 07:07 PM
kriseighty
Bronco II
Nov 8, 2001 07:54 AM
