Tire Load - "E" only for our trucks?
Old Apr 18, 2017 | 07:59 PM
hambass's Avatar
hambass
I tried searching, but cannot find an answer.
Do I need an "E" load if towing a small utility trailer to the dump...maybe 2500# max?
I see the BFG A/T KO, the old style, was discontinued, and now they have KO2, which I don't care for.
I'm looking for a similar look, not too aggressive; but not too highway, either.
Old Apr 18, 2017 | 08:15 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Depends on your tire size but even a stock size 265/75/16 D rated or Load index 119 tire inflated to the door sticker recommended 55 psi is capable of supporting 2625 pound per tire which conveniently jives with your rear axle weight rating Or GAWR of 5250 pounds.
So even towing at max capacity a D rated tire is sufficient.
Old Apr 18, 2017 | 08:16 PM
pirate4x4_camo
Load and inflation table for reference
https://toyotires-1524598101.netdna-...s_20170203.pdf
Old Apr 18, 2017 | 08:33 PM
hambass's Avatar
hambass
Thanks guys
Old Apr 19, 2017 | 12:50 PM
Big Sky's Avatar
Big Sky
Ford had a safety recall about 9-10 years ago to get rid of the D rated tires and switched to E rated tires. I'd rather be safe with the E rated tires.
Old Apr 19, 2017 | 01:23 PM
pirate4x4_camo
Do you have a link to the recall ?
Old Apr 19, 2017 | 02:09 PM
Big Sky's Avatar
Big Sky
Here is the link. I ended up with a set of nice Steeltex 10 ply tires. They lasted a long time. But I always run with Load Range E or 10 ply tires. Not worth the risk
https://www.ford-trucks.com/forums/2...re-recall.html
Old Apr 19, 2017 | 03:01 PM
pirate4x4_camo
That recall was specific to firestone tires, it was not and does not have anything to do with tire manufactures load and inflation rating system.
Not being critical of your tire choice but "load range E and 10 ply" tire technology is even more out dated then that firestone tire recall.
Load range 115 tires will exceed your rear axles GAWR
Old Apr 19, 2017 | 03:57 PM
Big Sky's Avatar
Big Sky
I know every time I get tires, they come recommended E range.
Old Apr 19, 2017 | 10:28 PM
05MilMachine's Avatar
05MilMachine
I certainly like the additional peace of mind that E rated tires give me when I am running heavy. Even if it is overkill, your tires aren't a bad place for it.
Old Apr 19, 2017 | 11:04 PM
hambass's Avatar
hambass
I am the original owner of my 2003 truck, so I benefited from the recall, I remember it.
Interestingly, I have ran the spare Firestone Steeltex wheel for the past 2 years (scissor blade went thru my BFG's), and it has not worn much. The BFG's have worn far quicker.
Old Apr 19, 2017 | 11:47 PM
william_04_x's Avatar
william_04_x
As long they aren't total crap, off brand, schit, WTF are you selling me rubbers.
They have different levels of confiidance, and protection.
Spend a few more bucks, and don't worry.
Old Apr 20, 2017 | 01:41 AM
Scott51's Avatar
Scott51
Here is the tire I'm putting on my Ex.
Pro Comp Xtreme MT2 radial 37x12.5x17 Load Range "D" Max load per tire 3525 lbs. makes it about a 124 load index. Plus these tires have a three ply sidewall, unlike 99% of the tires recommended for the Ex.
I drive semi's for a living and would not even worry about running a "D" range tire on the Excursion, unless it was some off brand junk.
I had this same tire on my Dodge Diesel, but in a 35" tire, and towed a car hauler with another Dodge diesel on it, and the tires were barely squatting.
Old Apr 20, 2017 | 01:42 AM
Scott51's Avatar
Scott51
Tire Load Index Chart | Tires Plus
Old Apr 20, 2017 | 09:41 AM
pirate4x4_camo
I also run a 37,
Should be noted that because of the volume a 37" @ 35 psi will support 2755 lbs each or 5510 total, right at the rear axles GAWR of 5250
Yup, I run my 37" at correct psi of 35 psi
