Explorer axle question.
Old Apr 28, 2017 | 07:00 PM
  #31
das54's Avatar
das54
A little more on the parking brake. I used the stock hand brake cable with a home made wish bone link to the Explorer cables. Used the short Explorer cable on both sides. More in my build thread. see post no. 161 https://www.ford-trucks.com/forums/1...a-f100-11.html
front half of the wish bone link
back half of the wish bone link
Old Apr 28, 2017 | 08:03 PM
  #32
petemcl's Avatar
petemcl
Thanks Dan. I thought that the short cables would be correct. Good job.
Old Apr 28, 2017 | 08:16 PM
  #33
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Thanks Dan!
Old Apr 29, 2017 | 08:31 AM
  #34
schoo's Avatar
schoo
Do both brakes have equal braking with the hand brake set or is one wheel holding more
Old Apr 29, 2017 | 10:59 AM
  #35
bjmayberry2
Roy they should both hold equally. Just as the originals do.
Old May 1, 2017 | 05:29 PM
  #36
das54's Avatar
das54
if the wish bone link is symmetrical then they should both set the same. And having grown up in Michigan I don't use it much at all, at least not as a matter of habit. In Michigan they tend to freeze (at least on old cars which is all I ever drove) from moisture or rust or both, and then you are stuck.
Old May 1, 2017 | 09:33 PM
  #37
petemcl's Avatar
petemcl
The problem is that if you don't use the ebrake system frequently enough it sticks in the engaged position wearing out the brakes. New sealed, SS cables help significantly.
revamp1953f100
Jan 21, 2018 10:32 PM
bjmayberry2
Apr 18, 2017 06:11 PM
Pablo-UA
1983 - 2012 Ranger & B-Series
Dec 29, 2014 05:09 PM
mstng5point0
16
Jan 2, 2012 10:10 PM
V8muscle
Oct 7, 2008 08:02 AM
