Explorer rear axle question
Old Oct 5, 2008 | 03:30 PM
V8muscle's Avatar
V8muscle
For those that have used an Explorer rear axle, did you reuse the spring pad or use a new one? If you used new ones, where did you find them? Was reading an article that seems to indicate that either the axle tube or brackets will be destroyed when removing them. Dont want to destroy either, but..... Looking around, it seems that all I can find are for 3 inch tubes, I guess those would work with some modification to changing the radius.
Bill
Old Oct 5, 2008 | 06:02 PM
jaye's Avatar
jaye
The part that will be destroyed are the spring pads, I used the shock brackets and U-bolts when I installed my explorer rear end. I used 3" spring pads and grind some off until they has contact all around the axle tube.
Old Oct 5, 2008 | 07:30 PM
reg1952's Avatar
reg1952
If the diff. came with the mounts on the back of the tubes for a sway bar they work perfect for new spring pads. They are narrower then the ones for the springs and fit the narrower springs on our trucks better. I just ground off the welds and smacked with a BFH to remove then rewelded in position.
Old Oct 6, 2008 | 10:21 AM
tip49's Avatar
tip49
Pads
Used the origianl pads on my 50 F1 from 2001 Explorer, re-welded to fit my installation. My springs are mounted outboard of frame, under axle.
Tom
Old Oct 6, 2008 | 12:41 PM
Lakotas53's Avatar
Lakotas53
Same here. I think there are some pics in my gallery under rebuild pics.
Old Oct 6, 2008 | 03:04 PM
V8muscle's Avatar
V8muscle
Thanks guys! I will see if I can get them off without destroying them, but if I do I will go with the 3in version and trim them to fit. Going to leave the sway bar brackets on there, I have the sway bar and going to try to use it as well.
Tom what did you do as far as shock mounting?
Old Oct 6, 2008 | 03:44 PM
tip49's Avatar
tip49
Shock mounts
I fabbed some shock mounts off the cross member mounted in front of the rear axle; using original stud bolts welded to the cross member at approx 45 degrees. Some pics in my gallery under rear suspension. I haven't road tested them yet, hope they hold.
Tom
Old Oct 6, 2008 | 03:51 PM
cmoritz's Avatar
cmoritz
V8, I cut the original pads off my axle...they were not very pretty when I finished that task. I also mounted custom spring hangers on the rear..outside the frame rails. Ended up trimming the 3" units for a good fit. As a side note on using the stock rear swaybar,
after swinging the unit up in place, using the stock swaybar to frame links, I found the bar was about 1.25" wider than the frame, about 3/4" wider on each side. I drilled some holes anywayplanning all along to build a couple of spacer/bosses to the frame...but after installing the fuel tank behind the rear...I thought it was getting pretty crowded back there and began second guessing where I could "possibly" sneak some exhaust pipes thru there...just something to think about.
I am currently looking at a front mounted swaybar to gain some much needed room,CCP has a rear swaybar kit thats looks like it may fit the Bill...
Old Oct 6, 2008 | 04:14 PM
jaye's Avatar
jaye
I also used the explorer U-bolts and shock brackets due to the explorer's rear end housing being larger than 3".
Old Oct 7, 2008 | 08:02 AM
mt54's Avatar
mt54
[quote=V8muscle;6620230]Thanks guys! I will see if I can get them off without destroying them, but if I do I will go with the 3in version and trim them to fit. Going to leave the sway bar brackets on there, I have the sway bar and going to try to use it as well.
I used the Explorer springs and swaybar, I then used Ford Ranger spring mounts,they needed shaved approx 1" to set in closer to the frame.
here are some pics
https://www.ford-trucks.com/user_gallery/displayimage.php?&photoid=44295&width=0
https://www.ford-trucks.com/user_gallery/displayimage.php?&photoid=44297&width=0
https://www.ford-trucks.com/user_gallery/displayimage.php?&photoid=45543&width=0
