front hub replacement
Old Apr 29, 2017 | 06:12 PM
  #31
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I think you might need to turn it while seating it. Maybe tap on it with a plastic/rubber hammer. Sounds like the teeth might not be lining up.
Old Apr 29, 2017 | 07:16 PM
  #32
andym's Avatar
andym
Put the snap ring as far down on the axle as you can and let go of it. Pull out on the axle with one hand and push in on the clip with a long screwdriver. I bet it will pop right into place.
Old Apr 29, 2017 | 10:12 PM
  #33
DavenTn's Avatar
DavenTn
make sure the large phenolic washer is behind the hub bearing against the hub seal. In other words.... large phenolic washer does not stack with the thrust washers.
Old Apr 30, 2017 | 07:44 PM
  #34
scubadiver's Avatar
scubadiver
Daventn,
You nailed it. I thought (poor memory) all the washers went outboard of the hub. I'll take it apart tomorrow, reassemble correctly and should be good to go. Thanks so much for politely reminding me to read the directions. DAAA
Old May 1, 2017 | 10:35 AM
  #35
DavenTn's Avatar
DavenTn
Originally Posted by scubadiver
Daventn,
Glad I could help.
Big E100
Jun 15, 2019 06:07 PM
tommytorino
1997 - 2003 F150
Mar 27, 2011 09:00 AM
caleb6.9
Apr 16, 2010 08:41 PM
Mr. Obvious
Apr 5, 2009 03:24 AM
MR DSL
1997 - 2003 F150
13
Jun 22, 2004 10:31 PM
