Be careful with Timken. My Timken hub came with the stud bolts but no nuts....I read to use old nuts and I don't have the M14x1.5 threads I have course threads. Now my truck is on stands and I cannot find anyone who has the M14x1.5 Grade 8 Nuts. Also no instructions at all. As far as thread locker or torque of studs into hub bearing assembely its all up to you. I snugged mine into the assembely with a small pipe wrench n used red loctite.
Heads up M14x1.5 doesn't exist in Grade 8 that may be why you can't find them. The M14x1.5 in a 10.9 is very common.
ford390gashog Thanks. I would take them if I could find them. I just thought 8 was the least I would use. Just can't find M14x1.5 anywhere and FOMOCO wants almost $8 a piece....I see Lug Nuts that would fit but they have the loose flange. Timken was lame to send the studs and not the nuts..lame
ford390gashog..thanks but its a wild goose chase.
Here is what I ordered: https://www.belmetric.com/fine-threa...nc-p-9732.html
$1.48 Each....
I was told that Class 10 is same as Grade 8 in Metric Nuts and Class 10.9 is same as Grade 8 in Metric Bolts. For some reason they only add the (.9) to the bolt Class description.... Add more confusion..lol
