Rear spring hangars
Old Apr 27, 2017 | 09:31 PM
  #31
richlars's Avatar
richlars
Originally Posted by Birdhunter1
When I replaced the rear hanger on my F 250 I took the bed off as I was also replacing a fuel tank and fuel lines....
I should probably start a new thread on this, but not quite sure how to do it. I was searching "fuel lines" and found this. Did you just replace the rubber, or the whole line? if just the rubber, did it take any special steps to transition from metal to new rubber? If the whole line, where did you find them?
Thanks, Rich
Old Apr 28, 2017 | 08:55 AM
  #32
Birdhunter1's Avatar
Birdhunter1
Thanks, Rich
I used rubber lines over the metal lines with a hose clamp. There are better ways to do it but that is what I did in a pinch to get the truck mobile. If it ever develops a leak I will probably go with a compression -barb adapter.
Old Apr 28, 2017 | 12:27 PM
  #33
Nothing Special's Avatar
Nothing Special
I should probably start a new thread on this, but not quite sure how to do it....
On the forum page there's a button on the left side, above the list of threads, that says "New Thread". Just hit that!
Old Apr 28, 2017 | 03:39 PM
  #34
richlars's Avatar
richlars
Thanks NS! I actually knew that but I wasn't sure if it would take the quote over to the knew thread and let BirdHunter know I was commenting on his post.
Old May 7, 2017 | 06:55 PM
  #35
thechief66's Avatar
thechief66
Well, I finished this job over the weekend....it is a BITCH to do with the bed and fuel tanks in place! Access is extremely tight on the left side, the fuel tanks and fuel lines are in the way.
The old hangars were rusted almost completely through!
I normally only use OEM parts on my truck, but the quality of the factory parts was obviously below par (more on this later) so I used the Dorman kit. Stripped off the paint that they come with and gave them 2 coats of epoxy paint-hopefully good for a long time.
The hardware included with the Dorman parts was crap-the bolts were fully threaded, allowing for considerable slop, which I didn't like. Spent quite a bit buying grade 8 bolts with 7/16 (rear) and 1/2 (front) shoulders on them which locate the hangars more solidly to the frame.
The factory spring hangars used on 90's Fords are obviously junk...mine were rusted away to nothing, and the rest of my truck isn't rusty (I live in a dry climate)
Just for comparison, I took a look at my dads 76 F250, which is 20 years older than my truck and has been a snowplow truck for over a decade. His spring hangars are in good shape!
Old May 7, 2017 | 07:12 PM
  #36
madpogue's Avatar
madpogue
Did the Dorman hangEr come with that hole at the bottom, or did you have to drill that?
Old May 7, 2017 | 08:09 PM
  #37
thechief66's Avatar
thechief66
They came that way.
cnice_37
Apr 10, 2013 08:20 AM
EX COT
1997 - 2003 F150
Feb 28, 2011 03:38 PM
TexasGuy001
13
May 12, 2007 02:47 PM
black460
Oct 20, 2004 01:11 PM
53Merc
Aug 4, 2004 08:04 AM
