Getting behind back seat
Old Apr 15, 2017 | 09:06 AM
ronnie1973's Avatar
ronnie1973
My 2010 f150 extended cab has a strap sticking up from behind the back seat that when I pull on it it doesn't move. I'm assuming that it should release the back of the seat so you can get behind it .
Am I correct and if I am any ideas how I could free it so I would have access behind it.
Thanks
Old Apr 15, 2017 | 12:52 PM
P.Bronner's Avatar
P.Bronner
I think that strap is a top anchor point for a child seat. I think there is a latch just outboard of the seat belt that has to be released by getting your hand in between the seat and back cushions. On my '05 I used a long screwdriver to push the latch. The trick was finding it. Google it, I bet there are a couple good YouTube tutorials.
Old Apr 16, 2017 | 09:41 AM
ronnie1973's Avatar
ronnie1973
Thanks I found several videos but haven't tried it yet
Ronnie1973
Old Apr 30, 2017 | 09:50 PM
brcman's Avatar
brcman
ronnie- can you share the link to a good video- I have not been able to find one.
Oldstuff
Old Apr 30, 2017 | 10:36 PM
seventyseven250's Avatar
seventyseven250
This sounds correct.
Old May 1, 2017 | 07:15 AM
Robbgt's Avatar
Robbgt
Supercab is not nearly as easy as the Supercrew (and that one isn't a picnic either...). The entire seat back is one piece and does not pivot forward like the Screw. It has to be removed entirely.
Old May 1, 2017 | 09:34 AM
ronnie1973's Avatar
ronnie1973
Thanks, After seeing video for extended cab I decided I didn't need to get behind seat, I was looking for storage but there appears to be none in my truck. The video that was posted yesterday by Robbgt convinced me.
Old May 1, 2017 | 09:16 PM
Ramonbo13's Avatar
Ramonbo13
Built Right Industries makes a nice adapter with a strap to release the top of the back seat. its $30 unfortunately. But I think it was a nice little addition to get to that storage area instead of having to feel around for the release.
Old May 2, 2017 | 12:00 AM
CuNmUdF250's Avatar
CuNmUdF250
Someone did a do it yourself mod for that it's on here somewhere.
Old May 3, 2017 | 11:13 PM
Mike728's Avatar
Mike728
There's a latch with a small metal tab about the size of a pencil eraser on the drivers side you have to lift up.
To access it on the supercrew you have to lift the 2 person seat up about 45 degrees. That pulls the back of the seat out enough that you can get to it just barely. Once you get the hang of it it's easy. It is a handy space. Second Amendment items fit back there nicely. Sometimes it's kind of hard to get the latch to close again. You need to raise the 2 person seat 45 degrees again, line it up and push hard to get it to catch.
Last edited by Mike728; May 4, 2017 at 08:56 AM. Reason: Supercrew description not supercab
Old May 4, 2017 | 06:14 AM
Robbgt's Avatar
Robbgt
Just to clear things up again folks, the SuperCrew (Full 4 door) and SuperCab (Half rear door) unfortunately do not use the same method to access behind the upper half of the back seat. The SuperCrew is much easier, as the seat back is split and there is already a mechanism accessible from the top to unlatch and fold forward.
For the SuperCab trucks, the seat back is all one piece and is not "hinged" like the SuperCrew.... the entire thing needs to be removed to access the space. Access to the removal brackets is from the bottom to latches then you pull the seatback up and out, clearing the center seat belt as well. Here is a better video than the one I posted before. Skip to 1:50 to skip the guys introduction. Video does a great job explaining on a SuperCab
tomatillo
2015 - 2020 F150
18
Dec 14, 2015 10:28 AM
rnuner
May 19, 2012 02:36 PM
RodSUT
Feb 18, 2011 03:37 PM
arrowheadfred
Aug 30, 2010 09:47 PM
lmorgan
1997 - 2003 F150
Jun 13, 2003 11:50 PM
