Dashboard Issue
Old May 1, 2017 | 01:00 PM
scottmeiners's Avatar
scottmeiners
Dashboard Issue
I just had my truck a the shop a couple weeks ago. The coil line for cylinder 5 went bad and caused my truck to run bad and have a flashing check engine light, all while towing my camper. Luckily I was still close to home and was able to use a friends truck to get my camper where it need to go. It's never fun to watch you truck leave on a wrecker. Anyway, while they had it, I went ahead an had them change all the plugs and wires. While they had it they also flashed the PCM to the latest update. This weekend when I was towing my camper I noticed that trailer that it said was connected was not the "camper" trailer that I created, it was on Default Trailer. This was no big deal, I figured out how to change the default trailer after I got home.
Now the issue that I have is I think the truck thinks it is still connected to a trailer. When I turn the truck on, the menu in the dash defaults to the Trailer screen, the towing mileage is still going up, and I see the trailer brake lights go up. The weird thing is that when I go into the system check, then to the brake controller area, it indicates that there is no trailer. I am not sure if this has to do with the PCM update or if something else is going on. I plan on plugging my truck back into the camper tonight, then unplugging it and see if that clears things up. Has anyone else had anything similar happen to their truck?
I currently have 56,000 miles on my truck and its starting to nickle and dime me and I am not liking it. fortunately I have an extended warranty with a 100 deductible. With 100 to fix the coil wire, 550 for the rest of the tune up and 100 for the turbo oil leak a few months ago, I am starting to get a bit frustrated.
Thanks,
Old May 1, 2017 | 04:33 PM
scottmeiners
I figured it out. I must have set the active trailer when my camper was not plugged into the truck. I went back in and change it to "no active trailer" and that seemed to solve my problem. I guess you can set an active trailer if you are towing something that does register with the truck.
Old May 4, 2017 | 10:34 PM
AbitaPro's Avatar
AbitaPro
Well as they say down here, "that's a good job PawPaw!"
That was too easy......
JD'sBigredv10
Nov 18, 2018 09:47 AM
Ewags
Jul 22, 2018 10:59 PM
pdarby
May 2, 2018 01:55 AM
grege
Mar 12, 2018 07:10 AM
DavidK2017
2015 - 2020 F150
May 11, 2017 02:14 PM
