DPF Regen?
Old Apr 18, 2017 | 08:37 PM
wb6anp's Avatar
wb6anp
Mine just stopped at 15%, also found out that none of the forscan lite dpf gauges match the trucks.
Old Apr 19, 2017 | 06:47 AM
Bomex1018's Avatar
Bomex1018
Originally Posted by Bomex1018
How low does your % go? Mine seems to hit 10% and stop.
when I shut it off yesterday it was at 10% now it's at 5%
Old Apr 19, 2017 | 09:16 AM
EpicCowlick's Avatar
EpicCowlick
This is interesting. I'm using FORScan Lite and am pretty sure the Soot % is accurate. The truck will fire off a regen when over 100%. The burnout lasts much longer on this truck than my 2011 and runs for about 30 mins, maybe more. But I have never seen the Soot % below 26%. It always shuts off a percent or two above that and the residual heat doesn't clean much more before soot starts to increase.
Another thing. On my last trip I saw exactly zero passive regeneration. With EGT's in the 700 and 800 range the soot % would just slowly climb. I'm thinking whaaaaat? What happened to my free cleanouts? It never decreases unless an active regen is going on. This is very different where I could tow with my 2011 and watch soot % drop into the negative percent range. Not happening on this truck.
And I know, I know... I don't really care what the regen is doing but
I....
JUST...
CAN'T...
LOOK...
AWAY.
It's like watching some supernatural higher power running mysterious algorithms and controlling my exhaust temps and mpgs. I definitely have not figured out this 2017. It is so different from the 2011.
Old Apr 19, 2017 | 10:03 AM
wharrell's Avatar
wharrell
Keep in mind the PCM is programmed to force a regeneration at 500 miles if the other parameters are not met at a 500 mile interval since the last regeneration
Old Apr 20, 2017 | 10:46 AM
ERock62's Avatar
ERock62
Pretty sure I had my first regen I noticed on my drive home last night.
I usually keep my info screen on the instant mpg's. I was very low on the drive home and I noticed my avg dropped a couple points.
Old Apr 20, 2017 | 11:27 AM
dsladdict's Avatar
dsladdict
Can anyone speak to the DPF status messages insofar as to if they were carried over from the 1st generation 6.7L. I have the 4.2" Productivity screen(sore subject) vs the 8" display. On my 2011 the message "DPF Regeneration in Progress" would show for a few seconds. I don't recall seeing that yet on my new truck. We so need an updated Coffee Table Book!
Old Apr 20, 2017 | 01:14 PM
wb6anp's Avatar
wb6anp
I....
JUST...
CAN'T...
LOOK...
AWAY.
I checked mine after regen, dash said 15% Forscan said 32% Ill try it again today.
Old Apr 20, 2017 | 03:08 PM
EpicCowlick
I hadn't considered that FORScan may be translating the PID incorrectly. Being that the regens start pretty much right at 100% I figured the low end of the scale would be accurate also. I'm fine with equating 26% with 0% if it really is the same.
Dittodog
Aug 15, 2020 06:13 AM
2021 Plow Beast
Feb 10, 2017 05:53 PM
scagwildcat
Dec 7, 2016 08:30 PM
A/Ox4
Oct 2, 2011 11:02 PM
nordy racer
May 28, 2010 12:49 AM
