DPF filter% screen for the 2017 ?
Old Mar 27, 2017 | 09:33 PM
Dittodog's Avatar
Dittodog
Question DPF filter% screen for the 2017 ?
Does anybody know if there is a ghost screen for the DPF filter % on the new 2017's that can be programmed into the truck, like they can on the 2014-2016 6.7l diesel ?
Old Mar 27, 2017 | 09:39 PM
silver_pilate's Avatar
silver_pilate
Yes, it can be done by the dealer. There's a thread on here from a few weeks back discussing the menus to navigate in Ford's programmer.
--Nathan
Old Mar 27, 2017 | 09:48 PM
Dittodog's Avatar
Dittodog
--Nathan
Thank you , I'll look again . I only seen the old stuff
Old Mar 27, 2017 | 09:54 PM
TrikeDawg's Avatar
TrikeDawg
Yes, I just got my truck back from the dealer today and I had the screen added.
Old Mar 27, 2017 | 10:10 PM
Dittodog's Avatar
Dittodog
Wow ! Thank you very much ! Ford is buying back my 2016 and I just ordered my 17 today and the dealer didn't know . Don't understanding why it doesn't come from the factory already done. Thank you for the pics of the steps,
Old Mar 27, 2017 | 10:22 PM
Dittodog's Avatar
Dittodog
Wow! Thank you very much for the information. Ford is buying back my 2016 and I just ordered my 17 today and they didn't Know if it could be done or not . I don't understand why it does not come already done from the factory . Thank you for the great pictures on the steps that they need to take
Old Mar 28, 2017 | 06:51 AM
CO Wapiti's Avatar
CO Wapiti
If you order the manual regen the screen is included already on the truck! I have an XLT and I ordered manual regen. The truck had the screen already programmed so this is what I'm assuming.
Old Mar 28, 2017 | 07:32 AM
wharrell's Avatar
wharrell
What issue did you have with your 2016?
Was it the Regeneration Jackhammer Valve Issue?
Old Mar 28, 2017 | 07:59 AM
BigJoeT's Avatar
BigJoeT
forgive my ignorance as I am relatively new to the diesel world, but when this gauge reaches near 100% does that indicate the truck will do something to clean this filter or is that a cue for you to replace it yourself? I ask because in the picture above the user has less than 1500 miles and is already 75% full.
Old Mar 28, 2017 | 08:09 AM
senix's Avatar
senix
The DPF soot at 100% is your indication that it going to go thru a regeneration process to burn off the soot in the DPF.
DPF does not need replacing.
What you will see if you pay attention is a notification that you are now cleaning the DPF.
then you can watch the soot % count down to zero or close to it to know that the cycle was completed.
Old Mar 28, 2017 | 08:24 AM
BigJoeT's Avatar
BigJoeT
gotcha, thanks for the explanation
Old Mar 28, 2017 | 08:34 AM
senix's Avatar
senix
bottom line here is EGT and fuel dilution.
Knowing you are in regen and that your EGT's will be high can allow you to run the cycle till completed or if you have to stop it then you can idle a few minutes to allow it to cool down (egt's).
Thus allowing you to burn off the fuel as well so you don't let it sit and then get the excess fuel added into your crankcase.
Old Mar 28, 2017 | 09:10 AM
Dittodog's Avatar
Dittodog
no, I have had extremely sensitive ABS problem they replaced everything from the steering wheel down to the hydraulic module and nothing fixed it . It seems more prevalent in the crew cab long bed 2014-2016 as far as I know . The ABS would activate driving at low speed's or Towing even with the brakes not on . While turning left or right up or down hill on a light bumpy road Or a simple transition from one street to another
Old Mar 28, 2017 | 09:39 AM
HRTKD's Avatar
HRTKD
I haven't seen any notification on my 2017 that a regen is in progress. I've been told that the new model no longer has that notification. I sure wish it did.
Old Mar 28, 2017 | 09:45 AM
mhoefer's Avatar
mhoefer
Correct HRTKD, there is no notification of the DPF cleaning in process on 2017 either. Be nice if we could program the popup and the % filter.
