Info Please on the 2017 Integrated Brake Controller
Old Apr 13, 2017 | 01:09 PM
rts9364's Avatar
rts9364
I am looking for a 2017 Lariat, 502A, etc. A lot of trucks in my area were apparently ordered with the tow package, but not Max Tow. As far as I can tell, the main functional difference in those two packages is the integrated brake controller. I'm trying to figure out how much this matters to me.
I don't plan to tow often, but there are possibilities coming up and I know it would be nice to have if/when needed. How difficult would it be to add only the brake controller later, assuming the truck has the standard Lariat tow pkg?
Old Apr 13, 2017 | 01:19 PM
GlueGuy's Avatar
GlueGuy
I added it to mine. It was pretty easy. The hardest part was finding the connector behind the dashboard.
Oh, and the computer need to be "told" that it has the controller. You can pay a dealer $50-$150 to turn it on, or you can do it yourself with forscan (and an OBD2 adapter).
Old Apr 13, 2017 | 01:34 PM
rts9364's Avatar
rts9364
Great. If the connector is there and it's just a matter of buying the part and updating software, I'm in. That is what I was hoping to hear as it may make my search a bit easier.
Thank you.
Old Apr 13, 2017 | 05:24 PM
TJReams's Avatar
TJReams
You also get a lower gear ratio with the max tow.
Old Apr 13, 2017 | 05:48 PM
scott91370's Avatar
scott91370
You can buy the part on eBay from a dealer for around $100 and use Forscan to turn it on after buying the obdii connector (around $80). Then you'll have Forscan for all the other options it can do.
Old Apr 13, 2017 | 07:53 PM
xr7gt390's Avatar
xr7gt390
It is possible to get the IBC on the standard tow package, mine came that way. It is a $275 option. I think the hitch is different on the Max Tow package.
Old Apr 13, 2017 | 09:43 PM
rts9364's Avatar
rts9364
Yeah, I've seen the stand alone IBC option, too.
According to my brochure max tow gets you the IBC and an "upgraded rear bumper," along with 3.55 gears. Most of the trucks I've been seeing have 3.55s regardless of the tow package, so I forgot about that.
Old Apr 13, 2017 | 09:46 PM
rts9364's Avatar
rts9364
Sounds like a must-have, and cheap compared to something like VW/Audi uses. I've been away from Ford a while (at least from an active enthusiast standpoint) so trying to catch up on things like this.
Old Apr 18, 2017 | 10:36 AM
Benztechnc's Avatar
Benztechnc
I installed mine in my 2015. Had a private shop program the truck for it. I have a 16 ft car trailer with electric brakes, which is why I wanted it. However, if you don't know whether your trailer with have electric brakes, it may not be useful. All I have is the standard tow package when I bought my truck.
The other thing I think I would like are the larger tow mirrors. Haven't tried a truck yet with them, but I think it would be very useful.
Old Apr 18, 2017 | 08:21 PM
Buzzard_Wing's Avatar
Buzzard_Wing
You may want to be cautious. I ordered an OEM controller from a dealer on eBay. Although the part number was right, it was totally the wrong part. I was scheduled to get the oil changed and have it installed (and 'flashed') at my dealer and was fit to be tied! I called the selling dealer and it turned out the mistake was fortuitous, the controller is specific to my truck. So the 'right' part would have been the wrong part. The seller (Quirk) was very helpful and happened to find my dealer's other location had the right part in stock. For my 2016 with backup assist, the correct number (using VIN) was FL3Z-19H332-AB. The total cost of the install and part was $330.
Old Apr 21, 2017 | 08:20 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
FL3Z-19H332-AB is the module I used to install in my 2016 Lariat, no backup assist.
Josh
Larietpsd
2015 - 2020 F150
16
May 11, 2016 01:57 PM
calidogj14
2009 - 2014 F150
Mar 13, 2010 06:42 AM
DW3555
Oct 7, 2009 02:20 PM
Quicktoy
Sep 26, 2006 10:06 AM
SD F350 99
All Things Towing
26
Feb 3, 2006 03:07 PM
