Cummins Swap Questions
Old Apr 12, 2017 | 05:59 PM
bradleyj's Avatar
bradleyj
I'm looking for an Excursion to swap a 12V Cummins into and I've found what looks to be a good candidate in a 2005 Ex, but it's a 5.4L V8, not a 6.8L V10. From what I've read, most Super Duty/Cummins swaps seem to start with a V10 truck so I'm wondering if this choice is going to cause me trouble.
One thing I know is that the 5.4L trucks come with 4.10 diffs while most V10s come with 3.73 diffs which would be better for a diesel. Would the higher gear ratio be a problem for the Cummins, especially when towing (which I do a lot of)? The engine I'd put in would be a 230HP/600ft-lb setup. Are the front and rear springs the same in the 5.4L V8 vs the V10?
Any other differences that would cause me trouble with this swap? I think I read that the V10 radiator is the same as used with the Powerstroke diesels and works fine with a Cummins, but not sure about the 5.4L.
Could anyone also confirm that all gasser Excursions 2000-2005 came with the 4R100 trans?
Old Apr 13, 2017 | 09:06 AM
Destroked 450's Avatar
Destroked 450
Most use the v10 chassis because of poor fuel mileage or they picked it up cheap.
4.10 are as low as you'd want with a Cummins, it will tow well but won't like interstate speeds unless your running 35" or taller tires.
You'll need the larger radiator and different front springs to support the added weight.
Not sure about the trans question but I think it would be questionable weather the 5.4's trans could handle the torque of the 5.9.
My Fummins is a manual trans so I usually stay away from the auto trans questions.
Is the Excursion a coil spring or leaf spring chassis, lots of spring choices either way.
Old Apr 14, 2017 | 04:09 AM
bradleyj's Avatar
bradleyj
All Excursions have front & rear leaf springs.
Old Apr 14, 2017 | 08:36 AM
Destroked 450
Wasn't sure, super duty's went to coil spring front in 05.
Depends wether you want stock ride height or lifted, my nephews 7.3 crew bad was sitting lower in the front than he liked, he replaced his 5600 lb springs with 6000 lb for a F-450 that lifted the front 3".
Check the spring code on the door tag to see what it has.
Old Apr 17, 2017 | 04:26 PM
gots_a_sol's Avatar
gots_a_sol
Excursions are way under sprung from the factory, so I'd plan on new springs no matter what. Stock 99-04 Super Duty springs fit in place and support the Ex much better. You should check out the tech folder in the Excursion sub forum here for more info on it.
Most guys are pulling out V10's because most gas Ex's are V10 powered.
Looking at rockauto, the V10 and 7.3 use the same radiator and the 5.4 uses a thinner one (assuming dual core vs single core).
My Ex was fine with the cummins/nv4500 and 3.73's with stock size tires. I have larger tires on it now and wish I had at least 3.93 (which they don't make for the Sterling rear grrr) but may go 4.10's in the future.
Old Apr 17, 2017 | 06:29 PM
bradleyj's Avatar
bradleyj
Thanks for the advice everyone.
Old Apr 27, 2017 | 03:05 PM
96Forge's Avatar
96Forge
You won't be able to use the 5.4 trans because as far as I know no one makes a adapter for a small block trans.
Old Jun 9, 2017 | 09:26 AM
bradleyj's Avatar
bradleyj
I just bought the engine for this swap out of a 98 Ram 2500 and I see that it's equipped with a transmission cooler that's cooled by the engine's coolant circuit. I'm wondering if I'd be better off sticking with the Ford's air-cooled trans cooler or rerouting the trans fluid lines into the liquid-cooled cooler on the Cummins. I'm thinking that the liquid-cooled cooler is probably more efficient but it means that the trans will be running at engine temperature pretty much all the time where with the air-cooled cooler it'll probably run at a lower temperature unless it's being worked heavily, and then it would be more likely to overheat. I do a lot of pretty heavy towing so this is a concern. Anyone have any thoughts on this?
Old Jun 9, 2017 | 09:32 AM
96Forge's Avatar
96Forge
My 97 Dodge Cummins has both the water and air cooler, but I deleted the water cooler and just use the air. I don't have a trans temp gauge so I don't know if it cools the same as when I had both.
I would think if the air cooler was big enough for the weight your towing it would be enough.
Old Jun 9, 2017 | 12:00 PM
Nothing Special's Avatar
Nothing Special
Mark Kovalski is a former Ford auto trans engineer who did a lot of work with auto trans coolers in his career. If I recall what he's written in threads like this, it's that the oil-to-water trans coolers are in the cold side of the radiator and are never anywhere near engine temp, so they do cool very well.
Old Nov 18, 2017 | 09:02 PM
humphrey169's Avatar
humphrey169
The 98 Cummins block is known to crack. Check to see if it's a 53 block before making any moves. Search 53 block and see
Old Nov 19, 2017 | 09:17 AM
bradleyj's Avatar
bradleyj
This is apparently not a problem with 12V 53 block engines. Only 24V:
Cummins 53 Block Casting Information
Old Nov 19, 2017 | 11:37 AM
humphrey169
True. Wasn't for sure if you went 24 or 12.
banshee rider81
Jan 25, 2014 11:39 AM
dsteinke
Oct 7, 2009 10:55 PM
05MSC
Jan 16, 2009 06:02 PM
Alaskan 78 F 250
Aug 2, 2007 12:52 PM
snakebit
Modular V10 (6.8l)
Mar 9, 2007 05:26 PM
