Easy to replace. Just have to make sure that the arm ends up underneath the cam lobe. The directions are usually over complicated, if you put it in with the arm angled down it goes in without any problems.
Disconnect the hose/hard line. Pull the two bolts and it comes off. Clean up the area on the block and use a new gasket.
