Upfitter switches
Old Apr 8, 2017 | 10:51 PM
Thurter's Avatar
Thurter
Upfitter switches
what are some good accessories that are not complicated installs that would be cool so my switches actually control something?
Old Apr 8, 2017 | 10:58 PM
MagicMtnDan's Avatar
MagicMtnDan
Lights, lights and lights! (LEDs). Front lights, rear lights, under truck lights (typically used for off roading to see the terrain at night).
Old Apr 8, 2017 | 11:51 PM
Ricohman's Avatar
Ricohman
Use one for an ARB compressor and another for the front locker.
Old Apr 9, 2017 | 12:04 AM
Thurter's Avatar
Thurter
Wait it so I can rig it to control my headlights? That would be cool. I'm new to super duty is that a complicated mod? I don't want to get too invasive and mess up my warranty. What does hooking up headlights or bed box lights to a switch entail?
Old Apr 9, 2017 | 12:21 AM
MJR777's Avatar
MJR777
They are talking about aftermarket LEDs for fog, driving, hunting, etc. Probably not a good idea to mess with the factory headlight controls - after all, how hard is it to turn the switch as opposed to flipping one!
Old Apr 9, 2017 | 04:18 AM
44Dan44's Avatar
44Dan44
*One of mine was going to be used to change one of the power ports in the console to constant power on when the truck is off but it might be handled already with a surprise Job 2 change.
*I will be using another constant power on for front and rear dash cam park mode recording.
*As MagicMtnDan mentioned above, a set of rock lights. While I won't be utilizing them for their intended purpose, I can see them having some good utility at the hunting lease or even simple undercarriage cleaning or inspection/repair.
*Rear mounted "reverse" or work lights.
Old Apr 9, 2017 | 09:03 AM
REPO.'s Avatar
REPO.
Old Apr 9, 2017 | 12:02 PM
Thurter's Avatar
Thurter
Ford?
does Ford install any acsessories for the switches that won't screw with warranty
Old Apr 9, 2017 | 02:41 PM
44Dan44's Avatar
44Dan44
Installing ANY accessory on the upfitter switches won't screw with warranty, that's their intended use. Ford sells some https://accessories.ford.com/vehicle...ectronics.html and to your question will install any accessory you pay them to install at shop rates
Old Apr 9, 2017 | 03:10 PM
bla1879's Avatar
bla1879
dont mean to but if my SD doesnt have the upfitter switches does it still have the wiring back there? Could I just buy the switches and plug them into the harness or would it require installing the wiring harness?
Old Apr 9, 2017 | 03:27 PM
44Dan44's Avatar
44Dan44
No, the wiring is not present unless built with upfitter switches from factory.
Old Apr 9, 2017 | 05:22 PM
Thurter's Avatar
Thurter
your the man. Thanks for the info "shop rates" I hear ya! Wish I knew someone in Tampa who capfuls do these mods
Old Apr 9, 2017 | 08:32 PM
KustomFX's Avatar
KustomFX
If you don't have interior sensors in your front facing mesh (or don't want them- move them up inside...), you could go with KustomFX mesh replacement switch panels.
You can email directly at: lethalweapon09@yahoo.com
dh1200
Jul 23, 2016 04:37 AM
woody367
Feb 20, 2008 11:32 AM
$Simpleman76
Mar 22, 2007 06:29 PM
No-Fish
Jan 20, 2005 11:18 PM
sud z
Oct 15, 2002 01:16 PM
