light on
Old Apr 8, 2017 | 02:21 PM
oughtsixbigred's Avatar
oughtsixbigred
light on
I have a 06 superduty and found a squirrel nest above the passenger wheel in the engine compartment, the reason I looked under the hood is my ABS light was on. I then found the right sensor wire chewed in two. I soldered it back together but the ABS light is still on. Could a relay have been blown in the chewing process? I unhooked the battery's thinking it would reset but it did not even after driving. How do I get the light cleared?
Old Apr 8, 2017 | 02:53 PM
FiznUKa's Avatar
FiznUKa
Replace the sensor. Use ForScan and check for codes.
BPofMD's Avatar
BPofMD
Veteran: Navy
I would look again in the engine compartment. I had the same thing happen to my 05 back in 06. Damage was MUCH worse... had to have the whole engine harness replaced...but I was lucky, my comp insurance paid for it. A week later the damn squirrels were at it again but I caught them before much damage was done and repaired that myself. Had to strip and solder 2-3 wires.
You may want to run a check on codes too. It may tell you why the light is still on.
Old Apr 8, 2017 | 02:59 PM
oughtsixbigred
BPofMD, that sucks. I hope mine is not that bad! I have a scan gauge 11 but no codes shown. Is there a test I can do to the sensor? Volt/OHMS?
Old Apr 8, 2017 | 03:05 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Some code readers are designed to read the abs codes. That's really what you need. It will usually be prominently displayed if it has that function unless it's a high end professional device. I guess they figure if you spend the big bucks you already know what it can do.
charles adams
Nov 22, 2022 08:56 PM
Strokin-8
Oct 9, 2010 02:26 PM
riverratba
Dec 9, 2009 08:29 PM
RA81222
1978 - 1996 Big Bronco
Nov 29, 2007 04:30 PM
dyarumian
Feb 17, 2004 09:09 PM
