ABS Light
Old Oct 7, 2010 | 08:26 AM
Strokin-8's Avatar
Strokin-8
ABS Light
Intermittently I get the abs light, havent pulled the codes. How likely is it the tone ring or just the sensor on the rearend?
Old Oct 7, 2010 | 08:29 AM
npccpartsman's Avatar
npccpartsman
Is it shifting crazy? It could just be a loose wire and the light is telling you which wheel or sensor is "faulty", so need to get it scanned....You could do that at the parts store while you're getting the VSS. I think they're real cheap anyway, but why waste the money??
Old Oct 7, 2010 | 09:20 AM
WH 6.0's Avatar
WH 6.0
My light was coming on intermittently and it was the sensor on the rear end. Mine would not come on during "in town" driving,only on the interstate during sustained 70 mph+ speeds if that helps. I hear tell the rear end sensors are fairly common so good chance that's it. Hope this helps!
Old Oct 7, 2010 | 09:52 AM
Zmann's Avatar
Zmann
they arent cheap anymore,, so try and clean it and check the connector
Old Oct 7, 2010 | 11:11 AM
npccpartsman
Maybe Partsguyed can pop in and give us a generic price on a VSS. They used to be like 8 or 10 dollars???
Old Oct 7, 2010 | 12:00 PM
Strokin-8's Avatar
Strokin-8
Thats it to a "T". Once in a greatr while I will get it on a short trip. Pulled it and it was clean. Connector and wire covers had alot of water in them. Dried and coated with dielectric grease.
I am going to Ford for other things and will check on price.
Old Oct 7, 2010 | 12:40 PM
WH 6.0's Avatar
WH 6.0
Cool,hopefully that's it. Glad I could help!!
Old Oct 7, 2010 | 05:38 PM
Zmann's Avatar
Zmann
the last thread I was reading stated it went from $20ish to $80??
Old Oct 7, 2010 | 06:29 PM
Strokin-8's Avatar
Strokin-8
68. + tax at dealership, coulda got it cheaper thru powerstroke shop but couldnt get there due to one of the major highwasys was closed today.
Old Oct 7, 2010 | 06:31 PM
Zmann's Avatar
Zmann
thx ,,,,,,,,,,,,,,
Old Oct 9, 2010 | 07:23 AM
npccpartsman
You'll need part number F85Z*9E731*AB, which runs $18.45. This is the one for my truck and the quote I got.
Old Oct 9, 2010 | 10:05 AM
Strokin-8's Avatar
Strokin-8
I picked mine up at the stalership earlier in the day, 6L3Z-9E731-A 2006 F-250 XLT. Time will tell if it fixed that problem with the truck. Still working on other issues. 34,000 mi. and this truck is requiring alot of attention from my bank acct.
Old Oct 9, 2010 | 01:39 PM
Zmann's Avatar
Zmann
you don't have your truck listed in your sig?
Old Oct 9, 2010 | 02:26 PM
Strokin-8's Avatar
Strokin-8
Tousley Ford $40.00
Powerstroke Shop $50.00
Tousley is cheaper on alot of parts but will have to pay shipping. Powerstroke is in indianapolis and i can go get.
