Speedometer cable
Old Apr 8, 2017 | 01:38 PM
62FE4x4's Avatar
62FE4x4
Speedometer cable
Does anyone know who sells a speedometer cable to fit a 67 F250 4x4? Thanks in advance
Old Apr 8, 2017 | 01:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C7TZ-17260-AA .. Speedometer Cable & Housing Assy - 101.42" long / Obsolete
1967/72 F250 4WD / No Ford dealer or obsolete parts vendor has any.
Old Apr 8, 2017 | 02:15 PM
RichS2659's Avatar
RichS2659
No luck finding any elsewhere so google for a custom maker like Texas Industrial Electric Co.
Old Apr 8, 2017 | 04:45 PM
MAD_MIKE's Avatar
MAD_MIKE
Is there a difference where/how the speedometer cable is attached on a 4wd vs a 2wd? Or is it a length issue? MT 2wd is 82" and is available from Rockauto from ATP Y801 for ~$9 + shipping.
If you still have the original cable can you measure the housing length?
EDIT: Nevermind saw NumberDummys post
Old Apr 8, 2017 | 05:00 PM
62FE4x4's Avatar
62FE4x4
Original cable had been cut off at the transfer case before I acquired the truck....
Old Apr 9, 2017 | 07:32 AM
lee's Avatar
lee
Hi,
Give these folks a call:
Tacoma Speedometer - Home
I've used them in the past, good folks.
Old Apr 9, 2017 | 09:43 AM
orich's Avatar
orich
If you've install a 205 T-case you'll need a different cable at the T case.
Orich
Old Apr 9, 2017 | 10:48 AM
62FE4x4's Avatar
62FE4x4
I am not sure which transfer case it has. It is actually a F350 crew cab 4x4 ordered new by the railroad in Montana. I was told the dealership sent it to Marmon-Herrington for the 4wd conversion. I listed it as a F250 4x4 because the F350 wasn't offered in 4wd until 1979 by Ford. I assumed the transfer case used would have been the transfer case for a 67 F250 4x4.
Old Apr 9, 2017 | 11:38 AM
RichS2659's Avatar
RichS2659
MH probably used a Dana 24 divorced case just like Ford did, but double check just to make sure that it is not a NP 205 which is different. Never assume things with Fords and especially conversions such as this. If it a NP 205 case, then you might be able to use a 68-74 Econolpne cable which is 104" and the right end at the transfer case.
Old Apr 9, 2017 | 12:12 PM
62FE4x4's Avatar
62FE4x4
What is a sure way to identify which transfer case I have? Is there a data plate on the transfer case? It is a divorced case.
Old Apr 9, 2017 | 11:27 PM
orich's Avatar
orich
The np 24 has a data plate in the side of it.
Where as the np 205 has it on front should be blue like pictured.
Orich
Old Apr 9, 2017 | 11:38 PM
62FE4x4's Avatar
62FE4x4
Fantastic. I will check it out as soon as I get it back from the transmission shop. Thanks
wildfoot6
Oct 12, 2012 09:52 AM
62-f100
Sep 4, 2008 06:58 PM
tgunn
Apr 20, 2005 11:37 PM
aunchman
Aug 7, 2002 10:39 AM
