in sheeps clothing...
In 2014 I purchased a 1961 unibody. Pretty good shape. Been sitting 18 years according to previous owner. I have put about 20 miles on it in the last 3 years. Just putting around the neighborhood and whatnot. This winter I decided to remove the engine and trans and clean it up/fresh paint. I began collecting all the parts I would need for what I intended.
MSD controller
Duraspark dizzy
'64 oil pump and shaft
New camshaft/timing set/lifters
Full gasket set
Clutch kit
Alternator conversion
TFI coil
Starter/ring gear
Seal kit for transmission
Water pump
I am a Ford technician by trade. Brought the power train to work and began with the trans. It's a T98A four speed. Everything looked great and sealed and painted nicely. Helps having $100000 paint booth in the building.
Monday of this week I began tearing the motor down. I knew the cam distributor drive gear teeth were chipped. When I pulled the front cover I realized I had collected $500 bucks in worthless parts..... timing gears. Steel crank. No fuel pump lobe. Cast iron timing cover. 262.
MSD controller
Duraspark dizzy
Full gasket set
Clutch kit
TFI coil
Starter/ring gear
Water pump
jpmillbauer
04-16-2014 08:35 AM
limptera13
03-27-2010 07:57 PM
unixadm
13
10-26-2007 12:53 PM
jcg82
01-10-2007 08:51 AM
