timing chain
Old Mar 26, 2010 | 05:12 PM
limptera13's Avatar
limptera13
timing chain
had to replace water pump and timing cover gasket so ima do the chain while im at it, am i correct that it is a one bolt gear? and i gonna repalce it should i go stock roller or double roller,
Old Mar 26, 2010 | 08:27 PM
Franklin2's Avatar
Franklin2
The camshaft gear is bolted with the fuel pump eccentric holding it on. I buy the stock timing set with a new steel gear on top and bottom. A lot of the engines have a plastic coated top gear.
You can get a true roller chain if you want to spend the extra money, but a regular gear will last a long time.
Just remember to drop the oil pan down a little bit to get the timing cover off. The best job is done by pulling the whole oil pan off, but if it's in the truck, that is too much trouble usually. A timing cover gasket kit will usually give you new pieces for the front of the oil pan seals.
While you are at it, check the crankshaft damper where the front timing cover seal runs. If it has a groove from the seal, they sell sleeves to press over the groove to repair it.
Old Mar 26, 2010 | 08:35 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Which motor? On a windsor motor just get a chain set for @ a 93, it's a double row roller.
Old Mar 26, 2010 | 08:48 PM
limptera13's Avatar
limptera13
302, btw, but ive never really gotten deep into a motor, always just the top end stuff, what is the fuel pump eccentric?
Old Mar 26, 2010 | 09:04 PM
ctubutis's Avatar
ctubutis
It's a cylinderical device that is mounted sort of off-center such a way that it pushes down
on the fuel pump's arm once per camshaft revolution. They look similar to this:
Installed, they're similar to this:
Old Mar 27, 2010 | 04:20 AM
limptera13's Avatar
limptera13
O ok. Yea I don't have one of those.
Old Mar 27, 2010 | 10:13 AM
Rogue_Wulff's Avatar
Rogue_Wulff
EFI 302 doesn't use the fuel pump eccentric. I'm not sure if the cam gear differs on the later models or not.
Old Mar 27, 2010 | 02:33 PM
Archion's Avatar
Archion
I have the 93 set on my 86, it's fine.
Old Mar 27, 2010 | 06:02 PM
limptera13's Avatar
limptera13
well they had a double roller on there but i replaced it back to the stock one only cause thats the only one i could get this weekend, it wont be a daily driver so, everything but the pulley n brackets are back together, ill find out tomorrow if i did a good job or not,. hoping i did haha
Old Mar 27, 2010 | 07:57 PM
Franklin2's Avatar
Franklin2
I have a 86 efi engine that does. But it only uses the one big cup looking piece, I guess they are using it as a large washer.
If you convert to a carb and fuel pump, you need to get the other outer ring piece that goes with it. The outer ring piece is what rubs on the eccentric, not the fuel pump arm.
Marksp78
Jan 15, 2013 06:20 PM
JoeP
Jun 29, 2011 09:33 AM
theFear
Jun 11, 2010 12:07 AM
lorenr
Nov 13, 2005 08:44 PM
ExplicitHP
Feb 4, 2002 05:18 PM
