22K with hubs in "LOCKED" position! Should I be concerned?
Based on the input of other members on here regarding a squealing noise, I went and checked the hubs - sure as ***** they have been in the "LOCKED" position since new.
Its a 2016 F-250, 6.2L gas truck with the electronic shift on the fly transfer case.
I have put right at 22,000 miles on it like this, frequently at 70-80 mph.
What are the odds I have damaged it and is there anything I should do now that I discovered it - other than put them both in "AUTO".
Appreciate any advice.
BTW - truck has been to the dealer twice and not once was this noticed. They blamed the squealing on the brakes which I knew it wasn't.
There might be some extra wear and tear on the front end but unless you plan on putting well over 100k on the truck I don't think you'll notice the wear. The biggest thing you'll notice is a drop in MPGs from leaving the hubs locked in.
The only problem I've encountered from leaving the hubs locked in for a long time is the dust seal for the pinion seal on the front axle will start to squeak, replacing the seal and bearing(they come as a complete unit)will make the sound go away. I've had to replace this part twice in the four years I've had the truck which I can't figure out because I know guys with SDs that never unlock their hubs and don't have any issues.
I have run my hubs locked for at least 60% of the over 100K miles on my'03 and have had no problems. Years ago these trucks did not come with lockouts as standard equipment and people put a ton of miles on them with no issue. Relax and don't worry about it. Also it is a GOOD idea to lock them once a month to make sure everything is lubed and exercised, you front axle and steering u-joints will thank you.
Kind of a dumb question but .... why would you ever want to leave the front hubs in the "locked" position on a electronic shift on the fly (ESOF) equipped truck?
What advantage could / would it provided? Never really understood the principal of having lockable hubs with a ESOF transfer case. What am I missing?
jesse_jamz
10-03-2006 11:18 PM
