Where can i find
Old Feb 27, 2017 | 12:33 AM
Karlow's Avatar
Karlow
Where can i find
A service kit for the locking hubs?
I lubed the front wheel bearing today with the needle adapter and grease gun. I cleaned the hubs, but the front seal in both hubs came out in pieces. That seems o be why they were so hard to turn. I need that front seal.
Old Feb 27, 2017 | 12:57 PM
AllaboutMPG's Avatar
AllaboutMPG
These?
Hublock O-rings For The Ford Diesel 7.3 Autolock Hubs
If your talking about the diaphragm in the bottom I don't know if it's replaceable.
Old Feb 27, 2017 | 02:07 PM
Karlow's Avatar
Karlow
I think that is the wrong one. It's the outer seal for the hub. I'm looking for the one that seals the cap that you turn to lock or unlock the hubs.
Old Feb 27, 2017 | 02:11 PM
AllaboutMPG
Read through this and see if you see it. If it's the diaphragm you may be looking at new hubs.
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Old Feb 27, 2017 | 02:33 PM
Karlow's Avatar
Karlow
That seems to be on Auto-lock hubs.
It does not show the seal in the end cap.
Thanks for trying!
Old Feb 27, 2017 | 02:39 PM
AllaboutMPG
So yours are manual locking? That's what I get for assuming
Old Feb 27, 2017 | 03:40 PM
clem1226's Avatar
clem1226
Autolock Hub Ring Clips (2) and o-rings (2) For the Ford 7.3 Diesel Front Hubs
I am pretty sure the auto lock and manual hubs use the same outer 0-ring and retaining ring.
This o-ring is not gong to make your hub turn freely though. You need to clean out and lube the dial. Take a look at guzzles write up on the procedure, it if for auto lock hubs so yours will be much easier and straight forward and a lot less parts. To disassemble the hub is one retaking ring and one snap ring.
I just did mine (manual hubs) Saturday because my wife has been using my truck and I hadn't realized how stiff they had become. They turn like a hot knife through warm butter now.
Old Feb 27, 2017 | 04:18 PM
Walleye Hunter's Avatar
Walleye Hunter
I just greased what I believe are Warn manual hubs on mine last week. I took that **** apart and found no evidence of a seal there so I don't know what stops water from getting in there. I went to my local hydraulic shop and they gave me two O-rings for $1.00.
Old Feb 27, 2017 | 04:57 PM
Karlow's Avatar
Karlow
Its the " dial" seal that I'm looking for.
When I took it apart it was stuck, and seal came out in pieces on both of them.
Mark, do you know the PN of those seals?
Most O-rings are A 568-XX. I do not believe the original seal were O-rings.
But an O-ring should work. Water had gotten into one of my hubs. It was not to bad, but it's been pretty dam dry in California the last few years.
The outer O-ring is easy to find.
Thanks
Old Feb 27, 2017 | 05:05 PM
AllaboutMPG
can you post a picture
Old Feb 27, 2017 | 05:44 PM
Walleye Hunter
I do not know any part numbers. I am blessed with several outlets for O-rings in my area and I just go in with the old O-ring and/or the part and get fitted up. When heat is involved it is essential to get Viton. Otherwise, as in this case, Butyl is acceptable. ACE hardware would probably have something that would work here.
Old Feb 27, 2017 | 06:09 PM
coax9952's Avatar
coax9952
I think you're gonna find that is The diaphragm in the end cap, and it is not field replaceable, they don't sell the part. And dorman doesn't even sell one. Time to buy a replacement auto hub....Dorman DOES sell one of those....
Old Feb 27, 2017 | 06:36 PM
hydro man 17's Avatar
hydro man 17
"Water had gotten into one of my hubs. It was not to bad, but it's been pretty dam dry in California the last few years."
__________________________________________________ _______________
Well it ain't dry this year! Well maybe a little in the Southland still.
Old Feb 27, 2017 | 06:41 PM
hydro man 17
__________________________________________________ ______________________
Now that's what I call planned obsolescence.
Old Feb 27, 2017 | 08:21 PM
coax9952's Avatar
coax9952
Exactly.... That's funny, I haven't heard that term since High School....Why sell you an O-ring when I can hit you for a Hub.
