Automatic front hubs DIY seal replacement question.
Old Oct 2, 2006 | 08:26 AM
jesse_jamz's Avatar
jesse_jamz
Can anybody link me up to part numbers of the inner and outter seals and a system blow-up. It is a 1999.5 ESOF with 'lock and auto' hubs. The vacuum pump is working but the hubs won't engage.
Thanks,
Old Oct 2, 2006 | 08:40 AM
dcf4x4's Avatar
dcf4x4
I'm afraid those are not exactly do it yourself hubs. From my searching on here, replace with warn hubs or bite the bullet for new autos.
If you happen to find something, though, I'm all ears. My right auto hub actually has part of a seal sticking out of the top of it.
Old Oct 2, 2006 | 08:44 AM
2002f2507.3LPS's Avatar
2002f2507.3LPS
is there a way to test if the auto engaging works? jack the whole truck up and turn it on and see if all four wheels spin?
Old Oct 2, 2006 | 08:50 AM
jesse_jamz's Avatar
jesse_jamz
I did have the truck on a lift and all 4 engage when the front hubs are locked, but NO engagement when in the auto position.
Old Oct 2, 2006 | 10:32 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Mine lock fine manually but they do not work in the auto position. Does your AC default to defrost? That is an indication of a vacuum leak with the hubs. If I work the auto switch mine goes straight to defrost.
Old Oct 2, 2006 | 12:02 PM
jesse_jamz's Avatar
jesse_jamz
HVAC works just fine. No straight to defrost so I have no leak - but I have no 4WD with auto set hubs. This truck has been sitting a while.
Old Oct 2, 2006 | 02:18 PM
brutusbux's Avatar
brutusbux
Try this page from the SuperDuty Tech Files...has a section on maint. for the autolock hubs
http://guzzle.rbmicro.com/
Old Oct 2, 2006 | 09:46 PM
Muktown's Avatar
Muktown
i used guzzles instructions and its pretty easy to do. i wouldnt go out and buy warns right away because if you can turn your hubs manually anyway you really dont gain anything by buying the warns. it sounds like you have a vacuum leak somewhere. check the vacuum lines going to the top of the hubs behind the rotors and wheel and see if they are cracked. i looked at mine and they were cracked about half an inch up the line from the barb where it slips over
Old Oct 3, 2006 | 11:18 PM
jtharvey's Avatar
jtharvey
Guzzle's site is great for helping with the clean and lube of the hubs. I did it, and mine turn much easier now. However, I still had a vaccum leak after all that. It turned out that the hub seals (the big ones in the knuckle) were bad and leaking. Once I replaced those, the auto lock works just fine again. I also replaced my rubber vaccum lines between the hub and the inner fender well because they wouldn't hold a vaccum. I had a post about it, so you might do a bit of searching to see what I did.
mikecwik
Apr 12, 2021 05:36 PM
pgguru
May 28, 2014 08:05 PM
richartdana44
Nov 27, 2011 07:57 PM
hedhntr
Oct 4, 2006 07:58 AM
