Steering wheel adapter? What do I need?
Old Apr 1, 2017 | 08:47 PM
351Cleveland C4's Avatar
351Cleveland C4
Who can shed some light on this for me? I'm somewhat lost here.
Thinking about putting a new steering wheel in my truck. Don't really like the old broken 3 spoke with three covers on it.
Anyway, because I don't have power steering I want to keep a large diameter wheel. And for a car, it's hard to find anything bigger than 14". SO, I started looking at 18" semi truck wheels. Plenty of cool options there. But I assume that they mount differently? I see 3 bolt holes....
I've also seen the steering adapter kits for wheels such as grant and the others. But I'm not sure exactly how they adapt? Are they splined like the shaft? Or use set screws?
Obviously, muscling an 18" wheel is gonna require things to be a little bit better than Chinese cast aluminum...
Old Apr 1, 2017 | 09:52 PM
351Cleveland C4
This is what I'm looking at.
https://www.ebay.com/itm/281992725950
Old Apr 1, 2017 | 10:36 PM
Serfbored's Avatar
Serfbored
Well, at $145 for the wheel, and $90 for the adapter, + whatever else you might have to purchase to make it fit, you are at, or above the cost of a repop wheel that you know will fit.
Old Apr 1, 2017 | 10:49 PM
351Cleveland C4
Well, yeah, but.... CUSTOM! besides, like I said in the first post, I'm really not crazy about the original wheels. Too skinny to get a grip on. That's why I have 3 covers on it. Fatten it up.
Old Apr 1, 2017 | 10:50 PM
351Cleveland C4
I can build an adapter plate. But I can't build a splined coupler. So I guess that's really the only thing I need.
Old Apr 1, 2017 | 11:15 PM
Serfbored's Avatar
Serfbored
So reuse the spline receiver from your original steering wheel, make an adapter plate, and get your big truck wheel. Adapter plate to attach to your original wheel spline, then tap 3 holes in it to accommodate the new wheel, then fashion the hub cover to fit it all. Looks like the big truck wheel comes with a nice deep hub cover.
Old Apr 1, 2017 | 11:21 PM
351Cleveland C4
The splined receiver is removeable??? I've had the wheel off a couple of times. Never thought it came apart.
Old Apr 1, 2017 | 11:27 PM
Serfbored's Avatar
Serfbored
Anything will come apart with a big enough cutting wheel.
If your original wheel is all broken and busted up, just cut the center out of it and remove the bakelite cover, and you have the center hub that you need.
Old Apr 1, 2017 | 11:30 PM
351Cleveland C4
True. That did cross my mind. I would like to examine other possibilities first though.
Old Apr 1, 2017 | 11:48 PM
Serfbored's Avatar
Serfbored
Doing that, my friend, is always a most excellent idea.
Old Apr 2, 2017 | 12:02 AM
orich's Avatar
orich
I forget the size of those old 5ton cargo army trucks but I'd say close to 20" steering wheels that was surly needed on those trucks and they had PS that was like no power steering at all. Trouble was after a hot sweaty 200 mile days drive your hands were black from the steering wheel. Paint would of helped though.
Orich
Old Apr 2, 2017 | 09:40 AM
Randle's Avatar
Randle
Most of the aftermarket 3-bolt steering wheels use a standard 3-bolt pattern. I have a Grant wheel on a GT performance adapter on mine. Even if the wheel isn't standard you could always re drill or slot the holes to fit the adapter and the horn button would cover it.
Old Apr 3, 2017 | 12:44 PM
TeachNlive4ever's Avatar
TeachNlive4ever
Awesome Garrett. Take the lead on this and I'll follow. I THINK I have an adaptor laying around somewhere and 2x what randle said.
Old Apr 3, 2017 | 03:47 PM
JEFFFAFA's Avatar
JEFFFAFA
How about a 80/82 B-F600/800 4 spoke steering wheel with the square horn button?
Picture Information
#mainImgHldr { display: table-cell; vertical-align: middle; background-position: center center; background-repeat:no-repeat; -ms-background-position-x: center; -ms-background-position-y: center; background-size: contain; background-image : url("http://thumbs.ebaystatic.com/images/g/7-QAAOxy~dNTJ51q/s-l225.jpg"); }
Old Apr 3, 2017 | 04:26 PM
JEFFFAFA's Avatar
JEFFFAFA
The original E0HZ3600A 4 spoke steering wheel had been replaced by ?????? and this spring.
But I do not have a slide to tell me what part number wheel is on Mat 82096. My 3/94 80/89 LT3 slide skips right over Mat 82096.
Aus56
Jul 30, 2017 05:33 PM
salf100
27
Jan 31, 2010 07:47 PM
ss383nova
Jan 12, 2010 06:28 PM
jmurder
Sep 28, 2006 08:41 PM
Poulsom
Jul 10, 2005 11:29 AM
