Illinois Chapter Join Chapter Leader: wpnaes
Illinois Chapter April 2017 BS thread
Old Apr 22, 2017 | 02:41 PM
  #1381
67nukeford's Avatar
67nukeford
Veteran: Navy
Good afternoon Illinois!!
Old Apr 22, 2017 | 07:44 PM
  #1382
56panelford's Avatar
56panelford
Good evening everyone, looks like nobody is home...
Old Apr 22, 2017 | 07:49 PM
  #1383
KOESTNER's Avatar
KOESTNER
I'm here John!
Old Apr 22, 2017 | 07:52 PM
  #1384
KOESTNER's Avatar
KOESTNER
Good evening Illinois, Shaun, Pat, and John!
hope that you had a better day today John.
Old Apr 22, 2017 | 07:53 PM
  #1385
56panelford
Originally Posted by KOESTNER
I think the whole front end tilts up as the hood so it should be easy to get to.
Just the hood tilts forward, got it running today, just needed time for the hydraulic lifters to fill with oil, pulled a couple push rods that were gummed up and ran it with the covers off. Everything is getting oil now and no knocking sounds. It smoked quite a bit after all the oil that was put in the cylinders. I added some trans fluid in with the engine oil to help clean things and free things up. I'll keep running it this way and do another compression test to see if things improve..
Old Apr 22, 2017 | 08:02 PM
  #1386
KOESTNER's Avatar
KOESTNER
Damn! I knew it had to be something simple, simple problems **** you off the most. I thought the whole front end tilted.
Old Apr 22, 2017 | 08:05 PM
  #1387
KOESTNER's Avatar
KOESTNER
I hope you feel better about Fords now!
  #1388
56panelford
Just like this..
Old Apr 22, 2017 | 08:08 PM
  #1389
56panelford
Time will tell, I knew I was taking a chance on this motor and figure it will get replaced eventually with a new crate, just not ready to do it now. I've spent far too much on this project in the past 3 years and most of it has been in the last 6 months..
Old Apr 22, 2017 | 08:09 PM
  #1390
KOESTNER's Avatar
KOESTNER
I wish I had seen that picture before I made a fool of myself in front of the world.
Its come a long way since that picture was taken?
Old Apr 22, 2017 | 08:10 PM
  #1391
56panelford
That was back in August 2015
Old Apr 22, 2017 | 08:12 PM
  #1392
KOESTNER's Avatar
KOESTNER
I don't think you need to invest in a crate motor, what you have will do fine as long as something doesn't pop up.
Did the transmission come from the donor truck also?
Old Apr 22, 2017 | 08:21 PM
  #1393
56panelford
Yes it did, C6. I drained all the oil out of it and changed the oil and filter in it. Was just topping up the oil in it today now that it is running.. taking tomorrow off and going to Dryden and will pick up some new plugs for it. It started to stall after it warms up but will need to check the timing and everything over. Hoping the more it runs everything will loosen up. It sounds real good with the dual exhaust..
Old Apr 22, 2017 | 08:22 PM
  #1394
donjamer's Avatar
donjamer
Good evening Rick, John, and everyone
hope you had a great Saturday..
Old Apr 22, 2017 | 08:25 PM
  #1395
56panelford
It was better than yesterday Don..
