Illinois Chapter Join Chapter Leader: wpnaes
Illinois Chapter April 2017 BS thread
Old Apr 20, 2017 | 09:49 PM
  #1291
KOESTNER's Avatar
KOESTNER
That will be costly to get back on the trailer and underway again.
If the load was properly blocked it shouldn't have come off, even if the driver made an abrupt turn.
Old Apr 20, 2017 | 09:52 PM
  #1292
fire240's Avatar
fire240
I think they have it back on the trailer at this point. The state is working to get the travel permits for the load reissued. Not to mention the other states it has to go through have to reissue permits for it. So until that happens it is parked.
Old Apr 20, 2017 | 09:56 PM
  #1293
KOESTNER's Avatar
KOESTNER
Probably did a number on the asphalt roadway.
Old Apr 20, 2017 | 09:57 PM
  #1294
fire240's Avatar
fire240
Yeah it did Rick. State has to go in and fix the road there. What really sucks is the fact they just repaved that section not too long ago now that alot of the road work in that area is finished.
Old Apr 20, 2017 | 10:00 PM
  #1295
donjamer's Avatar
donjamer
They are lucky it didn't do more damage or kill someone..
Old Apr 20, 2017 | 10:01 PM
  #1296
fire240's Avatar
fire240
Very lucky indeed Don. The city also has a traffic headache of its own right now. They had to close a bridge down for an unknow amount of time. They have to replace a water main That failed. It runs right down the middle of the bridge just under the road.
Old Apr 20, 2017 | 10:07 PM
  #1297
donjamer's Avatar
donjamer
That must have put a lot of stress on that bridge
Old Apr 20, 2017 | 10:08 PM
  #1298
fire240's Avatar
fire240
The bridge is leaking water right now Don. The water main that let go is a 20" main.
Old Apr 20, 2017 | 10:11 PM
  #1299
donjamer's Avatar
donjamer
They will need to inspect the bridge structure
Old Apr 20, 2017 | 10:13 PM
  #1300
KOESTNER's Avatar
KOESTNER
Must have carried a pretty good flow of water to keep from freezing during the Winter.
Old Apr 20, 2017 | 10:24 PM
  #1301
KOESTNER's Avatar
KOESTNER
Around the turn of the last century the commercial properties were supplied with steam heat that was piped under the River to downtown Peoria. Gets too cold here to pipe that across a bridge.
Old Apr 20, 2017 | 10:26 PM
  #1302
donjamer's Avatar
donjamer
You remember that form when you were a kid???
Old Apr 20, 2017 | 10:30 PM
  #1303
KOESTNER's Avatar
KOESTNER
Steam heat was supplied up into the 60s. I do remember steam escaping at the manhole covers in the streets.
Old Apr 20, 2017 | 10:34 PM
  #1304
donjamer's Avatar
donjamer
That was just my joke about your age...
Old Apr 20, 2017 | 10:36 PM
  #1305
KOESTNER's Avatar
KOESTNER
I know that. I've learned to let it blow by.
