Bigger injectors
Old Mar 29, 2017 | 08:36 PM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
Bigger injectors
I'm looking to put bigger injectors in my truck. Motor is stock with a SCT tuner on it. Just wondering what size would be good an if the fuel system needs to be upgraded when I put them in.
Old Mar 29, 2017 | 10:56 PM
2006powerstroke90's Avatar
2006powerstroke90
Look up Warren diesel they offer tons of options....some of which you can still use your stock fuel system
Old Mar 30, 2017 | 09:56 AM
05 f250 6 inch lift
I was looking at industrial injection injectors. Sounds like they have a good set.
Old Mar 30, 2017 | 11:04 PM
Sullid01's Avatar
Sullid01
probably at a minimum you need a fuel pressure sensor and the blue spring update. 155 with 30% nozzle or something like that should be good. You'll need some custom tunes for the new injectors. II makes good injectors.
Old Mar 31, 2017 | 05:12 AM
Bumblebee04's Avatar
Bumblebee04
Bigger injectors need more fuel. I foresee a regulated return & better pump in your future(according to my crystal ball)
Old Mar 31, 2017 | 06:13 AM
78fordman's Avatar
78fordman
Do you tow heavy with the truck?
Old Mar 31, 2017 | 02:09 PM
OneTon4Fun's Avatar
OneTon4Fun
Lager injectors mean bigger turbo too?
Old Mar 31, 2017 | 02:24 PM
Sullid01's Avatar
Sullid01
Generally, larger injectors are going to mean bigger turbo as well - the two should be sized together. You also need regulated return and bigger fuel pump, upgraded transmission to handle the power and unless you plan really well and are a bit conservative, your towing days are over. O-ring'ed head are another probable necessity.
I've thought about larger injectors a lot, but the project just seems to mushroom out of control. If you stick on the small side, most of the upgrades are optional but the power difference will be small and maybe not worth the extra expense. If you go larger, sooner or later, it is going to cost a lot. For example, a lot of guys wait on the transmission upgrades until they wreck their current transmission. I decided it was just too much money
Old Mar 31, 2017 | 03:50 PM
05 f250 6 inch lift
Don't really tow much with my truck. Sometimes a 89 mustang I use to drag race with an one in a blue moon I will pull a trailer with a decent size tractor on it.
I was looking at turbos too. I don't know how much the trans can handle an that's the last thing I want to tear up.
Old Mar 31, 2017 | 05:30 PM
Per4mance's Avatar
Per4mance
Greg and Dan have the right ideas, more power goes to more money. These trucks can get out of control really quick. If you have a unlimited pocket book then go for it,if not,I wouldn't play. I see how much fuel economy I can get now with a 9000 pound brick going down the highway and that gets out of control.
ol-blu
Mar 3, 2013 07:06 PM
roaringford
Mar 7, 2010 09:50 PM
neverman
Mar 22, 2009 02:31 PM
Bulldog68
Feb 2, 2008 09:33 AM
kaipo
Dec 31, 2006 10:21 AM
