Wet vs dry Intake pros/cons?
If you live in a cold climate the heat from the coolant will heat up the intake and possibly help prevent the carb from icing up.
That's actually a great question! I'd never considered WHY some intakes are dry while others are wet, just that some ARE.
The intake doesn't need the cooling-the block and the heads (where the combustion happens) is the part that generates all the heat, and even 195 is downright chilly compared to combustion temperatures.
I think the reason some intakes are wet is just how the engineers decided to route the coolant on that engine.
You got it. It's mostly just a matter of architecture. Of course this is not to be confused with wet vs. dry in fuel injected applications where a wet intake means that both fuel and air flow through the manifold, typically in TBI where the injectors are in the throttle body. A dry manifold means that only air flows through the runners and the fuel is injected down stream near the ports in the head.
dive2663225
02-26-2017 05:48 PM
bonzi88
03-18-2002 06:20 PM
