Motorcraft Fuel Filter FAIL
Yeah, it almost looks like an empty bowl with just fuel in it.
WHOA... forget what I said in my earlier post!!
Now that I look at it closer, I believe it IS an empty bowl after all, and what we're seeing is fuel sitting in there without the filter element. I can see vaguely the heater coil through the fuel around the edge of the bowl.
Stewart
WHAT!!!! Stew? The bung oring on the lower plate is what I think we're referring to that was left behind. It rides the stem like a Wyoming cowgirl.
Looks to me like the entire lower plate and bung oring are still in place. That's why I asked him to drain the bowl and post a picture empty.
See what we see. After my Circus story, I'm pretty damn sure what I'm looking at.
Wanna see it drained or will simply unsub.
Cap, oring upper, filter, lower plate, lower oring. plate (contains lower bung oring) I see lower plate, bung and that's what I'm gleaning from this portrait. If that is )IF) that's what we're looking at, doesn't matter if you threw a dishrag in for the upper seal. Your gonna puke fuel everywhere you travel until you have to call a hook!!!
If I'm wrong, I'm taking a class.
Sorry for the delay, I did empty the bowl and clean it well- the discoloration on the sides didn't come off. The photo is without the element and I did have it installed in the correct orientation. I hand tightened the cap after I lubricated and installed both the O-ring on the lower part of the filter element and the gasket which I fitted into the bowl and put the cap on top. I should have returned it right at that point but with no extra vehicle it would have been hard to do as the old filter was bad and actually came apart as I removed it.
The gasket is a QC failure, not even close to fitting correctly. I expect more from Motorcraft for the outrageous price from dealership. Although the UVCH I replaced was marked made in China so maybe I shouldn't expect much...
I ordered a motorcraft filter a month or two ago from amazon and I noticed that the o-ring was much bigger than it seemed it should be. I chalked it up to my not remembering what the old one looked like when it came off though. It doesn't seem to leak yet but you've got me wondering how tight that beveled o-ring should be around the threads of the lid.
I inspect and reuse mine. Sometimes if the new one is "relaxed" enough I'll use the new one but I don't see a reason to replace them every time just because. I replace mine at least once a year and if that darn gasket can't last at least two years, there's something wrong with it.
Stewart
Stewart
#30
Nathan_FM
01-26-2019 03:19 PM
FreeDevin
06-13-2015 09:23 AM
BDalton
13
03-08-2009 12:45 PM
